Old 14-05-18, 04:02 PM   #1
bigup
Default Battery Size for a Pointy
hey all
my battery has died and i need another one
i pulled the current battery out and its a BS Battery BT12A (https://bs-battery.com/bt12a-bs/)
It's dimensions are:
Length (mm) 150
Width (mm) 88
Height (mm) 105
ive had a look at other batteries like MotoBatt MBTX12U and Yuasa YTX12-BS and their dimensions show the height as 130mm.
Will these fit on my bike without modification? its a SV650s Pointy 2010.
wondering if the previous owner fitted a small sized battery?
thanks
bigup is offline   Reply With Quote
Old 14-05-18, 04:49 PM   #2
Chris_SVS
Chris_SVS's Avatar
Default Re: Battery Size for a Pointy
Both the batteries you listed will be fine. I'm almost positive (bad pun) the dead battery is the wrong size
Chris_SVS is offline   Reply With Quote
Old 14-05-18, 05:05 PM   #3
SV650rules
Some makers seem to give height measured over top of posts and others (IIRC) to top of case moulding.
2016 SV650 AL7
Old 14-05-18, 05:12 PM   #4
bigup
Thanks guys
Old 14-05-18, 08:22 PM   #5
bigup
Ordered YUASA BATTERY YTX12-BS from amazon in the end. £41 with prime.
Old 15-05-18, 08:36 AM   #6
SV650rules
Good choice, many years of trouble free use ahead.
2016 SV650 AL7
Old 15-05-18, 08:47 AM   #7
bigup
Ive also read these YTX12-BS are also AGM but they dont state this on the label, but it says on the datasheet
https://www.yuasa.co.uk/yuasa/datash.../sku/YTX12-BS/
either way, got my CTEK charger ready
Old 15-05-18, 05:39 PM   #8
SV650rules
Yeah, don't know why label does not have AGM on it, as it is a big selling point. AGM are ideal for bikes due to good cranking amps and vibration resistance and no leakage or maintenance required. AGM also have very low self discharge and are resistant to sulphation so can be left for long periods without use if needed and will not degrade as much as flooded type battery.
2016 SV650 AL7
Battery size ?!?! Strangwooduk SV Talk, Tuning & Tweaking 15 23-09-17 05:09 PM
New battery for Pointy - where from? jans1971 SV Talk, Tuning & Tweaking 5 11-04-14 08:33 PM
Pointy Battery DavieSV SV Talk, Tuning & Tweaking 2 08-06-09 10:27 PM
Does the pointy ECU have it's own battery? Baph SV Talk, Tuning & Tweaking 8 15-01-09 10:32 PM
Battery for 04 pointy, what, where, how? DF! SV Talk, Tuning & Tweaking 0 26-10-08 07:00 PM
