Old 03-06-18, 03:43 PM   #1
rick
Junior Member
Default 2013 cut out
Hey guy`s just wondered if any of you have encountered this issue and have any ideas on how to solve it
the bike is a 2013 sv650s fully faired 5500miles on clock everything appears to be working fine it revs out with no problems when ridden or at static, no misfires or stumbles it pulls strongly and starts instantly
the problem sometimes occurs when fully warm approaching a junction it cuts out , it restarts easily the idle is set at approx 1300rpm and is smooth but only does this occasionally not at every stop
would you think a dealer could diagnose the problem and if so could anyone recommend a good one in Herts/Beds/Bucks
many thanks Rick
rick is offline   Reply With Quote
Old 03-06-18, 07:35 PM   #2
rick
Junior Member
Default Re: 2013 cut out
It doesn't have standard levers i noticed there is no tag on the clutch perch to activate the clutch switch but as the pin on the switch was fully extended and the bike starts fine i didn't think it had an effect
maybe 2 in 10 mainly seems after stopping from higher speeds
never stalled when put in 1st
i tend to think about and change gears with a reasonable amount of time before the junction as i own and ride a tl1000r also, so you kinda get the feel for v twin idiosyncrasies
Old 03-06-18, 10:23 PM   #3
Grim-Lock
Grim-Lock's Avatar
fit original lever, buy new lever with the clutch tab or fabricate a clutch tab for your current lever. any of these will fix your issue.
have an l2 model myself and am thoroughly unimpressed with how intrusive the new ECU system is...
Grim-Lock is offline   Reply With Quote
Old 03-06-18, 10:38 PM   #4
a 2013 SV should not stall as it has an auto idle valve. they are also very sensitive to the safety circuit being messed with so bypassing the clutch switch is a no no.
there are two types of clutch lever. one is the older sliding clutch switch type and the other newer is the push pin clutch switch type. you must get the correct clutch lever. the later lever is the gladdy lever with a tab. the earlier ones dont have the tab.
Old 04-06-18, 09:04 AM   #5
rick
Junior Member
i will certainly give it a try as i still have the original levers and will let you know if it resolves the issue ....seems to be one of those items that has been developed and fitted for no real benefit lol
Old 04-06-18, 09:58 AM   #6
SV650rules
Had a look on SVRider forum, came up with this....
http://www.svrider.com/forum/showthr...ighlight=stall
2016 SV650 AL7
Old 04-06-18, 05:31 PM   #7
rick
Junior Member
This looks like one of those eureka moments ,i have just read the post and see what your referring to so will defiantly re-fit old lever and give it a try even though i love the adjustable ones
Old 04-06-18, 05:36 PM   #8
SV650rules
Or you could willingly fit the old lever ( autocorrect claims another victim LOL)
2016 SV650 AL7
Old 06-06-18, 08:34 PM   #9
rick
Junior Member
Well i gotta hand it to you guy`s "your good" a big thanks goes out to you all
i modded the lever so it activated the switch in the same way the original did and everything is cushty may even purchase another that has the correct tab
once again many thanks
Bsb 2013 NTECUK BSB & WSB 4 07-04-13 05:22 PM
Ar 2013 Thunderace The Madlanders 2 08-01-13 07:39 PM
Ar 2013 Thunderace East Anglian Revolution 0 08-01-13 06:48 PM
Ar 2013 Thunderace The Border Patrol 0 08-01-13 06:47 PM
Ar 2013 Thunderace Guildford Massive 99 21-11-12 09:55 PM
