Old 05-06-18, 06:57 AM   #1
svbmx
svbmx's Avatar
Default R/R fail. Replaced but no spark... help please.
Ride 1... blew a headlight bulb.
Ride 2... friend spots surging number plate bulbs.
Ride 3... a short ride but fine.
Ride 4 (attempt) 2 days later... battery completely dead.
Charged battery all day, still dead.
Symptoms above suggest to me R/R fail. So i replace the R/R with a mosfet upgrade unit and the battery with a new motobatt.
The bike now cranks but wont start.
I've checked all relevant wiring and fuses. Getting 13v to HT caps with ignition on. Plugs are getting wet so fuel isn't an issue. I replaced the plugs for new and still no spark. I also swapped the CDI for a known working item, still no spark.
So now I'm thinking pulse generator coil. Thoughts?
Any help would be much appreciated
Blue 99 SV650s... Naked SV/GSXR/Ducati Hybrid! Build Thread... HERE!
svbmx is offline   Reply With Quote
Old 05-06-18, 07:35 AM   #2
SV650rules
Default Re: R/R fail. Replaced but no spark... help please.
Excess voltage could have blown just about anything, 13 volts at HT cap may be be blown coil insulation.
2016 SV650 AL7
Old 05-06-18, 08:32 AM   #3
R1ffR4ff
R1ffR4ff's Avatar
Have you tested the Spark Plug caps.They come stock at 5k ohm resistance.Anything above 8k ohm and I replace them.
The Steed that replaced the SV DJ123 Photos 26 20-06-13 10:48 PM
The SV has been replaced... warrenhewitt10 Bikes - Talk & Issues 10 30-03-13 08:05 PM
Replaced reg-rec, now won't turn over. Tess SV Talk, Tuning & Tweaking 19 12-09-10 05:59 PM
SV Gone replaced with an RSV R Mille 04 danf1234 SV Talk, Tuning & Tweaking 11 17-08-07 07:21 AM
Battery Replaced chazzyb Ancillaries 4 06-09-06 12:07 PM
