Old 28-07-18, 10:53 AM   #1
bikerbaker
Default Curvy rear caliper
Hunting for a replacement rear caliper for my K1.
Looks the same as a Bandit rear from the same year (Dec 2000), any ideas?
TIA
bikerbaker is offline   Reply With Quote
Old 28-07-18, 11:20 AM   #2
Default Re: Curvy rear caliper
Hiya
The following use the same caliper
Bandits, tl1000, rf600/900
Zx6r j series and zx9r h through to end
The srad and k1 and k2 gixxers all models use the same caliper on a different disc iirc
Sent from my PRA-LX1 using Tapatalk
Old 28-07-18, 11:30 AM   #3
bikerbaker
Great! Thanks for the superfast reply.
That's the way to go as there are so many more around for the Bandit than the K1.
Old 28-07-18, 12:22 PM   #4
Biker Biggles
Biker Biggles's Avatar
ZX9R does not use the same caliper,at least the later ones dont.Ive got one and its a sliding job not an opposed job like the SV K1. I used to have a ZX6R and from memory that is not the same either.
I probably have an old curvy set of calipers in my shed if you want one---would need a rebuild though as they have sat there for a good few years.
Old 28-07-18, 01:14 PM   #5
There is one that does as I've bought seals and they're identical to suzuki
Old 28-07-18, 07:29 PM   #6
R1ffR4ff
R1ffR4ff's Avatar
Hiya
Thanks for that great info.
Also a while back I replaced some corroded bits on my Curvy Rear caliper.When I looked around at the individual prices for pins and springs from Suzuki parts suppliers to total mounted up with postage but I found this kit that worked at a much lower price for all the bits,
https://www.ebay.co.uk/itm/Suzuki-SV...72.m2749.l2649
I suspect the pins etc might fit the front calipers as well but not tested.
The Anti-Squeal retainer springs are a little different design to the ones I took off but still work/fit.
Old 07-08-18, 09:20 AM   #7
bikerbaker
I ended up with a refurbished caliper from a 2002 Hayabusa from a guy on eBay. My original was in a very poor state and would have needed pistons/seals/pins/pads plus the bottom plastic cover so it was the way to go.
I've always reckoned the K1 rear brake was too effective in comparison with the K6 single pot as I have managed to lock the back wheel in the past. This may have been due to the brake being semi seized for the past 5 years. Much better now!
Thanks again for the advice.
Curvy rear caliper. tim0o Stuff Wanted 7 23-04-13 08:45 AM
Curvy rear caliper MorganH91 Stuff Wanted 5 06-03-13 07:51 AM
Curvy Rear Caliper Binky Stuff Wanted 4 28-05-12 08:38 PM
curvy rear caliper husky03 For Sale - SV's and SV related items 4 11-03-12 08:56 AM
K3+ rear caliper on a <K3 curvy snoopy SV Talk, Tuning & Tweaking 9 30-03-05 06:49 PM
