Old 13-11-18, 07:27 PM   #1
simon1
Default bike stops when i let go of starter button
Hi
I have a curvy sv650....when I start it,,,as soon as I let go of the starter,it stops.....it will keep running if I keep the starter pressed down.....seems like an electrical issue??...bike has been standing for a few months....any ideas where I would start to find the problem?
Thanks
Old 13-11-18, 08:46 PM   #2
SV650rules
Default Re: bike stops when i let go of starter button
http://forums.sv650.org/showthread.php?t=231310
As luck would have it a wiring diagram posted today.
2016 SV650 AL7
Old 13-11-18, 09:30 PM   #3
simon1
Thanks..great diagram......
Old 14-11-18, 08:01 AM   #4
Craig380
Try this: switch ignition on, don't touch the starter button but bridge the connectors on the starter solenoid with an old screwdriver (wear gloves) to spin the starter. Does the bike start and keep running? If so, the problem is in the wiring to the starter button.
Old 14-11-18, 03:03 PM   #5
simon1
Hi
Tried that and didn't start.....it also dies if I release the clutch.....might try disabling the clutch switch?
Old 14-11-18, 03:36 PM   #6
SV650rules
If it dies with bike in neutral when clutch released may be neutral switch faulty or mechanically disconnected from mechanism.
2016 SV650 AL7
Old 15-11-18, 10:44 AM   #7
R1ffR4ff
R1ffR4ff's Avatar
+10
The neutral switch wires on my Curvy have been bridged so not in use.As per a recent post this is fine on the old 1999/2002 machines.
Old 15-11-18, 05:34 PM   #8
simon1
I followed the four wires up from behind the front sprocket..that plug into the main harness....this is the neutral switch?.....I unplugged it....and the same thing happened..motor dies as soon as I release the starter button......might need a new loom at this rate!!..
Old 15-11-18, 05:37 PM   #9
simon1
by the way I bypassed the clutch and side stand switches....before I did the neutral switch
Old 15-11-18, 06:17 PM   #10
Biker Biggles
Biker Biggles's Avatar
The sub loom that goes around the headstock area is often the cause of odd leccy faults in the switchgear handlebar area. Years of flexing lead to some strange shorting.
Starter Button Knackered Markos_46 SV Talk, Tuning & Tweaking 3 02-07-14 10:02 AM
Nothing on Starter Button Destruktor77 Bikes - Talk & Issues 14 04-09-11 10:32 AM
SV650S, no reaction to starter button mackemforever SV Talk, Tuning & Tweaking 20 07-01-11 09:05 PM
Starter button temperamental benp1 Bikes - Talk & Issues 9 01-07-09 06:32 PM
SV650 Starter Button? Torn-Thorax SV Talk, Tuning & Tweaking 3 09-09-06 02:49 PM
