Old 05-01-19, 10:29 PM   #1
ChrisF
Junior Member
Default Curvy Stator Issues. Bike cuts out
Hi there, I've been having some issues with my curvy recently. Battery died and bike wouldn't start a while back. Had a new battery in. Went well for a few months, until the bike cut out whilst riding. Electrics went first, then the bike begun to splutter until iflt finally stopped altogether.
After recharging the battery, I am able to start the bike but it dies very quickly afterwards in the same way as mentioned above.
I've replaced the RR as I had a spare lying about (also replaced the starter relay).
Battery voltage drops slightly when the bike is started, rather than 14ish volts that should be seen.
I have measured the resistances of my coils, all check out (around 0.5ohms).
I've also checked that my stator wires are not shorting to earth.
I was unable to run the bike long enough to get to 5000rpm to check the ac output from the stator, but while idling I was only getting 18v (supposedly 70 is required at 5000 rpm, not sure what reading is normal at idle).
I've also shorted my kickstand switch but the problem persists.
I am thinking that my stator needs replacing (only guessing, as I said before I'm not sure if my 18v was normal) , but before forking out on a new one I just want to see if there is anything else I can do, or if any one might have some other advice.
Any help would be very much appreciated!
ChrisF is offline   Reply With Quote
Old 06-01-19, 12:10 AM   #2
phi-dan
phi-dan's Avatar
Default Re: Curvy Stator Issues. Bike cuts out
I had a similar voltage issue last year, although mine didn't cut out, it just didn't charge the battery. As in your case, battery tested okay, r/r tested okay and stator tested okay, but low AC volts. When I took the stator cover off I found that the rotor magnets had either shattered, or were free floating
Not a common thing to happen...
I replaced the rotor with one from a breaker, and that solved that problem.
Unfortunately, shrapnel from the magnets later took out the oil pump, so that was the end of that.
Unless you've had the stator cover off recently you'll need a new gasket for re-assembly.
Was: Red curvy S: crash bungs, double bubble screen, fenda extenda, HEL front lines, OEM belly pan
Now: Blue FZ6 Fazer
phi-dan is offline   Reply With Quote
Old 06-01-19, 09:03 AM   #3
ChrisF
Junior Member
Thanks for the reply. I saw a video of a snapped magnet. The guy said he had never seen anything like it in 16 year. Seems to fit the bill though. I'll have a look later today if I can
Old 06-01-19, 09:58 AM   #4
ChrisF
Junior Member
Magnets on the rotor are all intact. However when I pulled off the stator cover a small, thimble size, stone dropped out. The coils don't look damaged from what I can see. Stuck again!
Old 07-01-19, 05:04 PM   #5
ChrisF
Junior Member
Bump
Old 08-01-19, 11:56 AM   #6
ChrisF
Junior Member
Originally Posted by Seeker View Post
I would have thought that the bike should run for a while on a charged battery even if the charging system wasn't functioning, unless the charging system (fault) is dragging the battery voltage down quickly.
Charge the battery, disconnect the r/r dc leads (maybe unplug headlamps?) and see if it runs for longer as a total loss system. It will let you know whether it's only a charging problem or whether you have another issue too. I don't know what voltage the curvy's igniter will stop working.
Even with the battery hooked up to my car still having the same symptoms. Surely this rules out the battery as the cause?
Old 08-01-19, 02:01 PM   #7
R1ffR4ff
R1ffR4ff's Avatar
It could be coil/s failure and even faulty plug caps can limit the engine.
See this post,
http://forums.sv650.org/showthread.p...hlight=SD05FMB
and I use the Red ones,
but these are the same,
https://www.ebay.co.uk/itm/Suzuki-SV...frcectupt=true
Old 08-01-19, 02:05 PM   #8
there should be nothing dropping out.. if it did then its been floating about in the engine = bad news.
the only thing that should come out of an engine is oil, everything else should be bolted down.
Old 08-01-19, 02:46 PM   #9
johnnyrod
johnnyrod's Avatar
Not looked in until now. Agreed connecting a second battery should rule out electrical problems, however the main connector on the starter relay that takes power to the loom can go, so unless you have bypassed this then it could still be at fault - mine had partially melted and started making intermittent contact and gave up in the end.
Old 08-01-19, 03:49 PM   #10
ChrisF
Junior Member
Appreciate the replies guys, all good stuff.
My spark plugs are less than a few months old but I'll get them out and test them anyway.
My starter relay is also new too, so doubt the issue lies there. I'll keep posting when I find out some more
Curvy stator and pulser coil hardhat_harry Stuff Wanted 1 25-08-18 03:34 PM
Curvy Stator Question TamSV SV Talk, Tuning & Tweaking 6 03-03-13 10:53 PM
pointy stator on a curvy? joker650 Bikes - Talk & Issues 4 03-12-12 12:08 AM
Curvy Leakage and Stator Tests TamSV SV Talk, Tuning & Tweaking 4 24-10-12 08:35 AM
Curvy won't idle reliably, cuts out. phatwheels SV Talk, Tuning & Tweaking 19 29-05-12 08:43 PM
