Old 18-03-19, 10:42 AM   #1
Craig380
Default Various 650 K6 parts for sale
As I don't have my 650 K6 any more, I'm selling a few bits I can no longer use.
Complete throttle body assembly
For a K3 - K6 SV650 (may also work with the later K7-onward machines, I'm not sure). In good condition, came from a low-mileage bike.
The assembly has both injectors, the STV motor (which turns freely using the nut), throttle cable guides & pulley, all linkages, all the original electrical connectors, and even the fuel hose that connects to the fuel pump outlet so it's ready to fit as a unit (doesn't include the inlet rubbers).
The assembly has an A2 restrictor plate fitted too (which stops the main throttle butterflies opening more than halfway) which is retained by a single screw.
Asking £30 including postage (UK mainland only)
Suzuki gel seat
Seat upholstery is good with only light use and no tears / holes / scuffs. The only problem is that one of the mounting eyelets (that the mounting bolts go through on each side) got stretched and broken. A new eyelet could be glued / plastic welded on, or you could simply remove the foam, gel and cover as a unit and put in on another seat base.
Asking £25 including postage (UK mainland only).
PM me for more details.
Old 28-05-19, 09:34 AM   #2
Craig380
Default Re: Various 650 K6 parts for sale
A quick bump
99-02 parts for sale - track bike parts wanted SVGTI For Sale - SV's and SV related items 15 26-12-12 11:32 AM
K3 Parts For Sale lawson17 For Sale - SV's and SV related items 14 13-04-09 03:11 AM
Many SV Parts for Sale twinsterpeter For Sale - SV's and SV related items 2 20-11-08 09:20 PM
FOR SALE: SV Parts and more geoff9 For Sale - SV's and SV related items 16 06-04-07 07:43 PM
SV 650 K4 Parts for Sale SV0wner For Sale - SV's and SV related items 5 09-11-06 05:10 PM
