Old 29-04-19, 12:21 AM   #1
lindsm
Default 99 SV650 Won't Start
I have a 99 SV 650 that won't start. Was working fine last summer. I rode it until about October. Left it out a little too late into the winter, uncovered. Now it won't start. I took off the air breather, and dumped some fuel down the carbs, fired right up, sounded good for a few seconds. I've verified that the fuel control valve is opening and letting fuel through. Changed the fuel. Verified the pump is coughing up gas, all though with this one, I'm not sure what an appropriate amount is. It didn't really start chugging out gas until the battery was almost dead from turning over. I charge up the battery between tries. When it turns over, it sounds good, but its not even trying to start. Like its not getting fuel. I have verified that there are no fuel leaks around the carbs themselves or the fuel lines. Inspected the vacuum hoses, everything appears in order. I did pull apart the fuel pump and discovered a lot of water in it. Cleaned that out, and did the fuel pump test successfully afterwards. I have a hard time picturing anything wrong with the carbs that would cause both of them to fail at the same time. I've been searching the forums a lot, haven't found an answer yet.
Any thoughts or suggestions? Don't want to miss a beautiful riding season.
Old 29-04-19, 06:33 AM   #2
Biker Biggles
Biker Biggles's Avatar
Default Re: 99 SV650 Won't Start
Water in the fuel pump? Where did that come from? I suspect you have wet fuel but finding out why is the issue.
Old 29-04-19, 06:35 AM   #3
Seeker
Seeker's Avatar
You have proved that the spark is there and it's only lack of fuel that's preventing it from running. Pouring fuel in via the air inlet would give a rich mixture so maybe your choke plungers are stuck.
If you left fuel in the carbs over the winter the ethanol in the petrol would have attracted any available water because it is hygroscopic, even water from the air. Once the ethanol and water combine they come out of solution and form a gunky gel that is superb at blocking jets. If the petrol has evaporated from the float chambers I suppose there is a chance the float valves have stuck and are not allowing fuel back in although I think this is less likely.
In any case it sounds like the carbs will have to come off for cleaning.
We have 5% ethanol in most of our petrol in the UK, in the US it is 10% and up to 15% in the winter months. Not many engines will run on 15% without modifications, they are marked "flex fuel" in the US.
In addition to being hygroscopic ethanol attacks rubber and some plastics and has questionable positive affects on pollution.
https://www.scientificamerican.com/a...ly-on-ethanol/
Old 29-04-19, 06:43 AM   #4
lindsm
Sorry, I wasn't clear on that. I live in Oregon, it rains all the time. That was probably when I was testing. Had things disconnected, but covered. Probably some condensation or runoff, or similar. Probably didn't cover up the ports on the fuel pump.
Old 29-04-19, 06:47 AM   #5
lindsm
Was hoping to not have to take apart the carbs. Seems like a lot of work. Thanks for the input seeker, will check that next. Have heard about ethanol issues multiple times now. Must be some truth to it
Old 29-04-19, 01:45 PM   #6
embee
embee's Avatar
If the fuel pump had water in it, the carbs will be full of water too. Usual suspect is that the drain pipe from the filler recess in the tank rusts through and lets water direct into the tank. If you take the drain hose off the bottom and block the tank stub then try blowing into the drain tube in the filler recess it shouldn't blow through into the tank.
Sounds like drain the tank, drain the carbs (there's a drain screw in the bottom/side, no need to strip completely at this stage), clean the hoses through.
If it's been trying to run on fuel poured directly into the intakes and there's water in the carbs it will have pulled water through into the combustion chambers and probably got onto the plugs too, so get them out and squirt a little WD40 or something in the cylinders to help dry them a bit, spin it over with the plugs out, then start from scratch.
If the tank drain is holed there isn't an easy fix. I believe some folk have fitted a sleeve through it with epoxy resin, but it's hit and miss whether you'll fix the leaks, it can leak water in and petrol/gas out.
Old 29-04-19, 08:09 PM   #7
R1ffR4ff
R1ffR4ff's Avatar
I used to have to use the Drain screws on my old Hondas carbs.If left in damp conditions moisture would build up in the Float Bowl bottoms over time causing startup problems and misfires.
Old 29-04-19, 09:27 PM   #8
lindsm
I think the water and the not running, while now related, didn't start off that way. I think the water was introduced when I pulled off the air breather and tank and lines recently to start checking into what was going on.
Old 30-04-19, 07:04 AM   #9
Biker Biggles
If you think the water is a red herring then its back to basics. Service the plugs and especially the choke plungers and cables. Is it very cold where you are? If so try and get it running with some flammable aerosol like easy start down the air intakes just to get some heat in it. If it runs when warm its back to those chokes. Make sure you have a fully charged battery and keep it that way. Check again there are no intake air leaks from the miles of rubber tubes including those two crankcase breathers.
Old 01-05-19, 05:05 PM   #10
lindsm
Pulled the carbs off last night. Opened the float bowls, pulled the main jet and fuel filter from each carb. Nothing that had me too concerned. The bowls had a couple of tiny white gooey balls in them. Really small. Smaller than a BB. Maybe 3 or 4 of them. I ordered some rebuild kits, replace all the gaskets and seals while I'm there.
05 sv650 won't start Conant47f SV Talk, Tuning & Tweaking 6 02-04-17 09:20 PM
Curvy SV650 won't start. liam111 Bikes - Talk & Issues 21 21-12-12 10:31 PM
My New SV650 Won't Start. toby_smith SV Talk, Tuning & Tweaking 40 03-04-10 12:54 PM
Cant get my new Sv650 K5 to start, have i flooded it? Mej SV Talk, Tuning & Tweaking 30 09-12-08 08:55 PM
SV650 won't start spmorgan SV Talk, Tuning & Tweaking 1 21-11-04 07:49 PM
