Old 02-08-19, 08:08 AM   #1
Yeti
Junior Member
Default Sv650s
Hi
Hope someone can help I have the SV650S 2002 curvy the problem I have is that the low/high beam also pass light do not work
I have checked fuses they are fine
Can anyone help me
Yeti is offline   Reply With Quote
Old 02-08-19, 08:30 AM   #2
Default Re: Sv650s
Check the terminals on the bulbs and check the connector block inside the fairing. Check the terminals in the handlebar switch gear. There's bound to be some corrosion somewhere
Old 02-08-19, 08:39 AM   #3
Yeti
Junior Member
Default Re: Sv650s
Thanks will take a look at these and see what I can find
Old 03-08-19, 12:26 AM   #4
squirrel_hunter
squirrel_hunter's Avatar
Default Re: Sv650s
Step 1: Check the bulb.
Step 2: Check for continuity at the switch.
Step 3: Check for continuity from the loom to the bulb.
Step 4: More information will be required.
If you need more details on any of those steps just ask.
"A little enthusiastic?"
SH2 | 2MA | GROM | YSR
Installing 2006 SV650S Pointy Clocks on a 1999 SV650S Curvy Badeye SV Talk, Tuning & Tweaking 0 13-08-15 12:49 PM
My K3 SV650s boredus Photos 7 15-03-10 08:19 PM
Can I fit an SV650s'03 FRONT END into my SV650s'99? TOLAROS SV Talk, Tuning & Tweaking 0 01-09-08 07:17 AM
My SV650S Craneman Photos 8 14-03-07 10:56 PM
SK3 SV650s pencil shavings SV Talk, Tuning & Tweaking 4 10-11-06 02:06 PM
