Added a quick connect charger cable and found one of the front seat bolts don’t tighten up. Any one had the same and have a fix.
Looks like it bolts to the subframe and feels like a captive bolt welded to the back. Not worth changing the subframe for that so a quick solution would do |
Ah, yes, I had that problem. I used a longer bolt and a nut behind the captive nut.
Not the most elegant thing I've ever done.
65 CB160 (67-69), 69 350GTR (69-72), 72 R5, 73 RD350 (73-84), 82 XZ550 Vision (84-03), 01 Concours C10 (03-19), 89 EX250 (11-14), 00 SV650S (14-16), 03 SV650S (19-) |
Exactly what I did too.
https://teulu.bandcamp.com/releases Blue Curvy S with over 110,000 miles and still going strong. ![]() |
Just be a bit careful about the wiring harnesses which hide behind those seat bolts. It was always one of the standard things to check when electrical gremlins afflicted a curvy, the bolts would project through and chafe the harness.
I actually found that the original bolt was long enough to get a shallow nut onto.
Cheers chaps. I managed to find a nut lurking in the tool box and managed to get it behind the frame. It seems the screw goes into the harness, probably not the best routing of cables but didn’t feel any damage to the harness so all good
#7 | |
(While I was there, I wrapped a short length of split flexible plastic conduit around the loom behind to reduce risk of electrical gremlins. The loom tape was showing visible signs of rubbing.)
Spannering the wife's SV650S K5 pointy in Black, and son's SV650 X curvy in Blue. RIP SV650 X curvy, crashed and written off December 2019. I'm (procrastinating about) fixing up an old Yamaha FZ600 to get myself fully back on the road. |
Curvy seat bolt | Pricey12 | Stuff Wanted | 8 | 22-08-15 07:34 AM |
Curvy seat bolt wanted | Pricey12 | Stuff Wanted | 4 | 09-07-14 10:37 AM |
Front tank allen bolt curvy | beabert | Stuff Wanted | 4 | 20-06-11 08:15 PM |
curvy fuel tank front mount bolt and sleeve. | leebex | Stuff Wanted | 1 | 23-10-10 11:37 PM |
Curvy front seat | simonthepost | Stuff Wanted | 6 | 20-05-08 07:11 PM |
