Old 25-03-20, 05:05 AM   #1
sv650blue
Default Odometer not ticking over
I have the original instrument panel on my 2003 Suzuki SV650 and just today I noticed the odometer has stopped registering any new distance travelled. My panel only has wires going into it and all other functions are ok. So I was wondering if anyone has experience with this. Perhaps it's a sensor or broken wire?
Thanks.
Old 25-03-20, 08:57 AM   #2
Seeker
Seeker's Avatar
Default Re: Odometer not ticking over
If the speedo is still working then it sounds like an internal fault in the panel.
2016 SV650AL7
2023 GSX-8S
Old 26-03-20, 03:43 AM   #3
sv650blue
No, the other indications, lights, tacho etc are fine, speed and odometer are not working.
Old 26-03-20, 06:53 AM   #4
daktulos
daktulos's Avatar
Search the forum for pointy rotor - if the speedo has gone to, it's likely to be this, particularly if you've had the front wheel off recently.
daktulos is offline   Reply With Quote
Old 26-03-20, 08:24 AM   #5
shiftin_gear98
shiftin_gear98's Avatar
Sounds like you have a lug missing.
Currently driving a Corsa....
Old 24-05-20, 05:59 AM   #6
sv650blue
I finally got a replacement part for my disintegrated speedo sensor. It's from a 2007 model but the applicability is OK for my 2003. The problem is the speedo is reading double the speed and distance travelled.
Any ideas?
Old 24-05-20, 06:32 AM   #7
sv650blue
I'm reading around and it seems that the rotor changed after 2004!
Old 25-05-20, 09:39 AM   #8
Sean_Morgan
Did you manage to find a rotor yet ?
Ive just had to order one for my 2003.
They have what looks like a pattern one on wemoto for £38, I found an oem one in Ebay but it's coming from Germany.
I'll sort a link out for you
Sent from my SM-G960F using Tapatalk
Sean_Morgan is offline   Reply With Quote
Old 25-05-20, 09:40 AM   #9
Sean_Morgan
https://www.ebay.co.uk/itm/274371961170
k9 speedo/odometer problem Markus01 SV Talk, Tuning & Tweaking 4 10-06-18 11:15 PM
Odometer LCD blank Gregor16 SV Talk, Tuning & Tweaking 0 10-04-14 05:42 PM
Odometer not tallying miles vs km MisterTommyH Bikes - Talk & Issues 3 29-05-13 08:58 PM
Odometer freaking out adam87sneaky97 SV Talk, Tuning & Tweaking 7 11-10-08 01:10 PM
Can you trust the odometer? phizog SV Talk, Tuning & Tweaking 14 09-11-07 10:47 PM
