Old 03-04-20, 01:00 PM   #1
pedro3178
Default Brake lines
Hi,
I bought new brake lines ( Venhill ) for my SV650S 2001 . The rear one was absolutely perfect . I went to do the front and noticed the line is much longer. I have been told this is definitely for my bike , am I being stupid here ?
I’ve tried everything to upload images here but it’s not working! Here are links
https://postimg.cc/tYcb5GyC
https://postimg.cc/Btbrbw9T
Old 03-04-20, 01:06 PM   #2
Dave20046
Dave20046's Avatar
Default Re: Brake lines
Originally Posted by pedro3178 View Post
Hi,
Are you posive they've not supplied you one for the the sv650x or N which are naked and presumably have higher bars so a longer line?
I don't recall the stock setup, your new line will go from mastercylinder to caliper - did your old one or did it go to a splitter somewhere on the front of the bike?
Old 03-04-20, 01:18 PM   #3
pedro3178
Thanks for reply.
On the Venhill packaging it does state Suzuki SV650S 1999-2002 . My brake lines go up and into the splitter like you say.
Old 03-04-20, 02:39 PM   #4
Dave20046
Dave20046's Avatar
Thanks for reply.
Right, then Venhill should have sent you two of those lines and a long double banjo bolt for the mastercylinder (unless you've switched to single rotor). You just put both into the mastercylinder side by side and one line routed carefully to each caliper.
Or if you've been done a bit you can run to one caliper and buy a cheap short one to run from one caliper to the other but you'll need different banjos foreach caliper and I can;t imagine it's worth it.
Old 03-04-20, 02:54 PM   #5
pedro3178
You’ve cracked it! They did indeed send a double banjo! Cheers mate!
Old 03-04-20, 03:28 PM   #6
Dave20046
Dave20046's Avatar
Make sure you renew the copper washers and put one separating the hoses where they double up.
so: |0|0|
otherwise just one either side at the caliper.
Old 03-04-20, 03:31 PM   #7
pedro3178
so: |0|0|
Will do, cheers for that
Old 04-04-20, 04:10 PM   #8
pedro3178
Cheers Dave! Got the brake lines done today. Thanks again for the help
Old 04-04-20, 06:29 PM   #9
Dave20046
Dave20046's Avatar
Thumbs up Re: Brake lines
Glad you're sorted
Standard Brake calipers complete brake lines and master cylinder for sale dblakey For Sale - Other Bikes and General biking items 0 29-06-16 07:55 PM
Wanted pointy rear undertray or tail tidy, braided brake lines, wavy brake discs. Chris*2700 Stuff Wanted 3 07-10-12 11:25 AM
SV Racing Parts, GSXR Brake Caliper Adapter Brackets, & Galfer SS Brake Lines & Pads sv-racing-parts SV Talk, Tuning & Tweaking 42 15-09-11 10:27 PM
HEL Brake Lines buckstone SV Talk, Tuning & Tweaking 1 20-05-08 04:24 AM
HEL brake lines streetos SV Talk, Tuning & Tweaking 4 31-03-05 09:51 PM
