Any of you knowledgeable folk out there know why the thermostat on our immersion heater keeps tripping when the round metal cover is on it? If I take the cover off it heats the water without tripping. It's a Backer Backersafe immersion heater element with the 18" thermostat. The cover is the right one for the device so it's got me baffled. It obviously overheats with the cover on but surely it shouldn't?
https://teulu.bandcamp.com/releases Blue Curvy S with over 111,000 miles and still going strong. ![]() |
I've had to replace a couple of the dual safety thermostats because of tripping out. I suspect it's a fine line between tripping too early and too late. If it was mine I'd bite the bullet and just replace it, they're not hugely expensive.
Out of interest what temperature setting do you have the stat set at? You could always try it with the temp set 10C lower as a start. Have you checked whether the stat temp dial switching actually corresponds reasonably with the water temp using an independent thermometer/thermocouple ?
I have just bought another thermostat to be on the safe side but it’s not yet fitted. Don’t know what temp it’s set at as although it has lines to denote hotter or colder it doesn’t have any numbers on it. Think I might set it back a notch and see what happens. It’s currently on the factory setting.
Hot water tank control stat should be at 55 to 60 deg C - any hotter risks scalding any cooler risks legionella. Safety trip is probably set at 80 to 90 degrees just to stop water boiling, they normally work on a capillary tube where the contents expand as temperature rises. If there is loose connection on immersion heater terminals or contacts it could cause higher temp inside case.. as said previous replace stat as they are not megabucks..
Factory setting on stats normally 60 deg C.
2016 SV650 AL7 Courage is resistance to fear, mastery of fear, not absence of fear - Mark Twain Last edited by SV650rules; 15-07-20 at 07:10 PM. |
Thanks chaps. I have a new one here. I’ll add the fitting of it to my ever expanding list of jobs for tomorrow
If you mark factory setting with permanent marker as 60 you have a reference to go back to..
The thermostat on my hot water cylinder was set at 60 degrees for years ,then it went haywire so was replaced, then set it at 50 because water was scalding hot, recently turned it down below 50. I assume numbers on dial don't bear much relation to actual water temperature. British Gas engineer said just adjusting them can sometimes stop them working properly !
stop feeding it shrooms then...
#9 |
#10 | |
Faulty Thermostat? | AlexAdams | Bikes - Talk & Issues | 5 | 05-05-16 07:05 PM |
75 degree thermostat? | ronscotty | SV Talk, Tuning & Tweaking | 3 | 17-08-10 07:42 PM |
Thermostat Housing | cammy | SV Talk, Tuning & Tweaking | 4 | 24-04-09 09:29 PM |
Thermostat Switch Help | warrenhewitt10 | SV Talk, Tuning & Tweaking | 24 | 16-02-09 06:14 PM |
Am I tripping out? | Blue_SV650S | SV Talk, Tuning & Tweaking | 13 | 24-09-06 04:00 PM |
