Old 18-09-20, 09:18 PM   #1
DickP
Default 2000 Curvy suspension refresh
Hi
I am planning to refresh the suspension on my SV650 Curvy over the winter.
Who are the suggested retailers for the ktech for springs which appear recommended?
I weigh roughly 82kg so suggestion on spring rate and oil thickness welcome.
I also saw a chart some time ago indicating alternative rear shocks that fit the SV650, rather than keeping stock. Has anyone got this to hand and have any recommendations?
Thanks,
DickP is offline   Reply With Quote
Old 18-09-20, 09:29 PM   #2
wsmc549
Default Re: 2000 Curvy suspension refresh
Ebay is a good place to start. 10 or 15 weight depending on your weight riding style. ZX6/10 shock is common for Gen2 because the shocks are the same length. 330mm. I believe Gen 1 had a longer shock. 345mm or so but you could always lower the front to match the rear.
wsmc549 is offline   Reply With Quote
Old 19-09-20, 10:41 AM   #3
embee
embee's Avatar
I have purchased springs directly from k-tech. Try their "store" on the website, or there are stockists shown. Give them a ring to confirm what you need.
https://www.ktechsuspension.com/
I am about 12st or 76kg and have 0.85kg/mm (8.5N/mm) springs which are comfy, you might feel 0.9kg/mm would suit you better.
Similarly I use Fuchs/Silkolene Maintain RSF 7.5W which is comfy, for a stiffer spring and more weight you might prefer the 10W.
The RSF 7.5W is pretty much the same viscosity as many commercial 10W oils at 35cSt here http://peterverdone.com/wiki/?title=Suspension_Fluid
(it used to be called Silkolene PRO RSF, now called "Maintain" RSF, I usually use https://www.sportsbikeshop.co.uk/mot...ontent_cat/809 )
Old 05-10-20, 10:12 PM   #4
DickP
Hi guys,
Thanks for the help. Will take a look at the link.
Old 08-10-20, 09:21 PM   #5
DickP
Hi,
Just coming back to this, for the rear suspension what options are there for the first generation SV650?
Thanks,
Old 09-10-20, 03:51 PM   #6
gadget
Originally Posted by DickP View Post
Hi,
Thanks,
For the rear suspension, you have three or four choices, a slab of Victoria sponge, plasticine, foam rubber, or the spring from a parker pen. Each one has it's own merits and are a good cheap alternative but all are a vast improvement over the oem shock !
gadget is offline   Reply With Quote
Old 11-10-20, 09:05 PM   #7
Dave20046
Dave20046's Avatar
Hi,
Thanks,
Nitron were very popular 'int day' weren't they? If you can find a second hand one and have it serviced that would be a good move.
If looking for something cheaper , you'd have to do a bit of searching for conversions. Think the kwak zx6r and some gsxr shocks were popular.
2002 SV refresh Claude Bikes - Talk & Issues 66 07-09-15 09:33 AM
BMW S1000RR gets mid-life refresh NewsBot News 0 01-07-13 10:30 AM
Soft front suspension - Normal on 2000 Curvy S? StewartR SV Talk, Tuning & Tweaking 4 29-04-12 12:54 PM
2000 650 suspension mod Avtjr64 SV Talk, Tuning & Tweaking 5 09-09-05 09:25 PM
