Old 10-03-21, 01:23 PM   #1
Seeker
Seeker's Avatar
Default Mainspring linear generator
Low NOx standby generator.
https://www.mainspringenergy.com/technology
They say there's no flame/combustion because the "reaction" temp is below 1500°C which lowers NOx but no mention of CO2?
2016 SV650AL7
2023 GSX-8S
Old 11-03-21, 09:43 PM   #2
johnnyrod
johnnyrod's Avatar
Default Re: Mainspring linear generator
Interesting idea. if you burn anything containing carbon you get CO2, there is no way around this, but on the flame front NOx is formed which is an undesirable but unavoidable by-product. What you really need to know is its efficiency at turning the stored chemical energy into electricity, and then really the whole lifecycle - where does the fuel come from. But that's another story.
Old 12-03-21, 10:03 AM   #3
embee
embee's Avatar
Back in the dim and distant past I was on a group where we assessed external technical submissions to the company ("forward engineering"). We got a lot of things like this to consider.
The fundamental questions are what is the thermodynamic cycle, the inherent efficiency limitations, and as said above, what is the energy source.
This is a typical thermodynamic compression/heat input/expansion cycle, and so the thermal efficiency is readily evaluated. The rest of the device is just mechanism wrapped round the cycle to get the work out in a usable form.
Distilling devices down like this meant that nearly all such "novel" ideas were just a standard process in a slightly different physical shape wrapped up in different nuts and bolts.
Thermodynamically I'd be very surprised if it is any different to any other cycle either in common use or having been used at some time. Mechanically it's questionable why a linear arrangement should be much more practical or desirable than a rotary device (air springs are not 100% efficient for example, heat is lost). Component/material temperature regulation is frequently an afterthought in these things.
As far as their claims for emission/efficiencies, it really does come down to what the chemical process is which provides the heat energy, and I'd want to see a lot more detail. In principle thermodynamic cycles are more efficient the higher the temperature and pressure they operate at and the shorter the cycle times (heat loss), so their claims for a low temp/press "reaction" process would be a big question mark in my mind.
Very often tech submissions we got to assess ended up with some element of "perpetual motion machine" included in order to achieve the sort of efficiencies being claimed.
The reasons why the typical internal combustion engine still works more or less as it did 100yrs ago are fundamental, you can't cheat thermodynamics. Mechanisms and materials evolve, but the process stays the same. It is not for the lack of ideas.
Old 12-03-21, 01:42 PM   #4
keith_d
keith_d's Avatar
There are some slightly odd claims in their technical brief..
"electrically-controlled linear motion of oscillators compress a fuel and air mixture until the mixture reacts uniformly and near instantaneously"
"the reaction occurs at low temperatures (less than 1500 C)"
My first thoughts are that this using catalytic oxidation rather than conventional combustion. Presumably that means a sintered catalyst which is heated by a mixture of adiabatic compression and residual heat from previous cycles. However, this places some severe constraints on their choice of fuel. Ethanol is the obvious candidate.
Anyone got access to a patent search to see what they've registered??
Keith.
Linear linkage robertw95 Racing and Paddock Chat 2 14-11-15 11:19 AM
K3> linear rear linkage. lawson17 For Sale - SV's and SV related items 0 01-05-15 06:07 PM
Linear Springs yorkie_chris Stuff Wanted 0 20-07-07 12:24 PM
Linear or Progressive?? M65 SV Talk, Tuning & Tweaking 11 31-03-06 12:23 PM
Linear springs for K3 Stef SV Talk, Tuning & Tweaking 5 16-03-05 08:57 PM
