Old 31-05-21, 07:28 AM   #1
Seeker
Seeker's Avatar
Default ASV brake lever
Do ASV brake levers (or equivalent) allow the lever to come closer to the handlebar? Since breaking my wrist I find it harder and slightly painful to stretch to the lever. The SV is not so bad but the Kawasaki is worse even with the adjustment set to its closest position.
2016 SV650AL7
2023 GSX-8S
Old 31-05-21, 09:55 AM   #2
Default Re: ASV brake lever
i would not buy AVS but the chinese ones instead. but to answer your question, yes they are adjustable for span. if your bike already has adjustable leavers then i doubt you would gain much. beware adjusting the clutch lever too close as it can mess with gear changes.
i think a better idea would be to give yourself some physio on the hand.
Old 03-06-21, 02:56 PM   #3
Seeker
Seeker's Avatar
I just had a reply from Oberon Performance, they're a British company that make adjustable brake levers. I inquired about the difference in styles of brake lever for the Z900RS. They replied saying they don't make levers for Kawasaki's.
Here's a link to their webpage: https://www.oberon-performance.co.uk...lever-lev-b300
2016 SV650AL7
2023 GSX-8S
Old 11-06-21, 10:29 AM   #4
Seeker
Seeker's Avatar
I try and avoid supporting the Chinese Communist Party whenever possible.
Well, I bought the ASV levers and yes, they give far more adjustment - the minimum distance between the leading edge of the brake lever and the leading edge of the handlebar is 48mm. This is a meaningless number to you since I didn't measure the stock distance but be assured it's much closer.
Yes, I am having physio but the tingling/numbness in my finger tips may take a year to clear (if it ever does). Physio addresses the range of motion but the nerve issues can only be fixed with time (or so I'm told).
2016 SV650AL7
2023 GSX-8S
RH Footpeg Hanger, Rear Brake Lever and Clutch Lever for 2004 Naked Wanted Drumming_Animal Stuff Wanted 0 26-07-10 10:52 PM
Curvy brake lever & rear brake pedal Old Git Stuff Wanted 1 09-01-10 11:00 AM
WTD - rear brake lever, front brake lever, r & G crash bung, nik_nunez Stuff Wanted 0 17-10-08 08:27 PM
Gear lever as rear brake lever? plowsie SV Talk, Tuning & Tweaking 2 29-05-07 05:23 PM
clutch lever and front brake lever Quiff Wichard For Sale - SV's and SV related items 4 19-03-07 12:05 AM
