Old 24-06-21, 07:07 PM   #1
Kenzie
Kenzie's Avatar
Default E10 Fuel
Evening all, I have read that E10 unleaded fuel is to be rolled out to replace the currently available E5 fuel in 95 Ron. I have checked the online compatibility site and it says it should not be an issue. My bike is a 2008 K7 twin spark. Should I continue as normal when they switch to E10 or could I use 98 Ron E5? I have read that the "Super" unleaded will remain as E5.
Sent from my F5321 using Tapatalk
Old 24-06-21, 07:32 PM   #2
DJ123
DJ123's Avatar
Default Re: E10 Fuel
Think there was a thread on this not too long ago. Most injected bikes will be fine, only Carbs, IIRC, will be a bit more effected.
http://forums.sv650.org/showthread.p...hlight=ethanol
BMW F800ST
Old 24-06-21, 07:44 PM   #3
Kenzie
Kenzie's Avatar
Thanks. Will I see much difference running 98 over 95?
Old 24-06-21, 07:48 PM   #4
Seeker
Seeker's Avatar
...from the UK gov website:
Suzuki
E10 petrol is cleared for use in all current production models with petrol engines.
For older models: Please refer to Owner's Manual
2002 Model Years and onwards - all motorcycles can use E10 with no problems.
1992-2001 Model Years – some models can use E10 fuels and some models cannot. The user should contact his national importer for clarification.
1991 Model Years and earlier – RON 98 (no bio-fuel content) must be used.
https://check-vehicle-compatibility-...acturer/Suzuki
The main problem with ethanol is its love of water - not a problem if the vehicle is used regularly but if not used for months can cause issues. Your mpg may get slightly worse with E10.
2016 SV650AL7
2023 GSX-8S
Old 24-06-21, 07:50 PM   #5
DJ123
DJ123's Avatar
Not really. My mantra on bike fuel is; Supermarket filling station=Super Unleaded, any brand station=normal petrol.
My MPG is pretty consistent if i do this, and the bike runs fine.
BMW F800ST
Old 24-06-21, 07:57 PM   #6
SV650rules
Gonna need this more than ever - especially over winter when bike not used, doesn't need much.
https://www.ebay.co.uk/p/27034903769
2016 SV650 AL7
Old 24-06-21, 10:59 PM   #7
might be being dumb here but wont the higher content of ethanol be better for carbed bikes in the winter to help stop carb freezing? seem to recall that isopropyl was used for that purpose.
i think the media are going a bit nutz over this. yes you might drop a few mpg but not much. i get 60mpg on the bike so expect to drop to say 58. no biggie. will it eat fuel lines and gaskets? maybe in really old bikes (that are probably goosed anyway) so best use a stabiliser/additive. service manuals usually state to change fuel, brake, breather, vacuum etc.etc lines every 4 years or so anyway, how may people do that?
i dont care what it is as long as it makes my bikes/cars piston's go up and down.
Old 25-06-21, 03:42 PM   #8
SV650rules
Well the more ethanol in petrol the more water is likely to be in there ( ethanol attracts water ) so the water will freeze before the petrol.... I am puzzled as to how destroying rainforest to grow huge areas of monocrops that deplete the already poor soil, which then gets washed away ( and never gets replaced ) just to add to fuel qualifies as 'green and good for the planet'.
2016 SV650 AL7
Old 25-06-21, 09:52 PM   #9
johnnyrod
johnnyrod's Avatar
Water will only freeze if it is as free water, adding something like an alcohol is a co-solvent so keeps all three in a single solution. The green credentials of ethanol fuel are a bit shaky, best from sugar cane, worst from corn IIRC. As for octane number, no you won't notice anything.
2008 SV650 Fuel Cap/Fuel Pump jwray4422 SV Talk, Tuning & Tweaking 3 26-06-18 06:27 PM
WTD, curvy fuel tap and fuel level sensor northwind Stuff Wanted 3 06-12-17 12:33 PM
Fuel rant whinge moans hate fuel prices bah Daimo Idle Banter 54 18-02-11 11:02 PM
Where is the fuel? Lifted fuel tank. BoomBoomBox Bikes - Talk & Issues 72 07-12-10 01:01 PM
Replacement fuel light / fuel tap riktherider SV Talk, Tuning & Tweaking 7 14-05-07 06:41 PM
