Old 05-07-21, 05:12 PM   #1
gadget
Default Curvy engine temp
Just a quick question... does anyone here with a curvy know what the engine temperature is supposed to reach as the fan cuts In? I'm not having any cooling issues and fan cuts in and out ok. But as a curvy isn't blessed with a temp gauge I thought I might give the radiator/thermostat housing a check with one of those Laser temp checking gizmos.
gadget is offline   Reply With Quote
Old 05-07-21, 05:34 PM   #2
Seeker
Seeker's Avatar
Default Re: Curvy engine temp
the manual says that the fan thermo-switch should change from OFF to ON at approx 96°C and change back from ON to OFF at 91°C.
They recommend testing it in a pot of oil using a thermometer and a multimeter.
2016 SV650AL7
2023 GSX-8S
Old 05-07-21, 06:46 PM   #3
gadget
Thanks for the reply, I have no real reason to test the thermostat as the fan only ever comes on after it's been idling for about 10 minutes, I plan to point the laser thermometer at the radiator header tank and the thermostat just as the fan kicks in, if it's at the recommended temperature or damned close I'll probably leave the actual thermostat alone.
Old 06-07-21, 08:27 AM   #4
R1ffR4ff
R1ffR4ff's Avatar
I have a cheap Temp sensor LCD on my bars. Sensor attached to Thermostat switch @ the rad. My fan comes on around 95 Deg C and my average running temps depending on the ambient temp of the day is between 50/60 Deg C @ 60/70 mph air-cooling.
If left idling to test fan once it's kicked in and out it usually holds the engine around 82 Deg C which is the average Thermostat opening temp.
https://www.ebay.co.uk/itm/303585881...8AAOSwmutgXUTD
Old picture and Volt meter has been changed for a blue one,
Old 06-07-21, 04:48 PM   #5
gadget
Cool, excuse the pun! How exactly did you attach the temp sensor to the Thermostat switch? Did you have to wire it in or attach it in some other way? Cheers.
Old 06-07-21, 05:09 PM   #6
R1ffR4ff
R1ffR4ff's Avatar
The temp gauge has a single wire probe so nothing fancy needed. I just threaded it to the Fan switch at the Rad, pulled back the rubber cover and then used a tie-wrap to hold it in place and then cover with the rubber cover. I just used a couple of small tie-wraps to lock the Gauge onto the bars so easy to remove if ever needed
Old 06-07-21, 05:15 PM   #7
gadget
Seems like a good way to keep an eye on temps, dirt cheap too.
Thanks for the info and pics, really helpful. Cheers. ... btw ... how long does the battery last?
Old 06-07-21, 05:22 PM   #8
R1ffR4ff
R1ffR4ff's Avatar
I think at least a year or more. I think they are the AG13 type. The unit is not really waterproof so consider coating it in something clear.
https://www.ebay.co.uk/itm/142106743...MAAOSwFNZWt2sh
Mine's been on a couple of years but comes and goes now but usually works after a few miles. It may need taking off and the battery replacing and cleaning the battery contacts/holder but they are cheap to replace if it has gone.
Old 06-07-21, 06:41 PM   #9
gadget
Thanks for that, I don't use my bike at all in the wet tbh, my days of being soaked through are well 'n' truly over so the gauge being waterproof isn't really an issue.
I think I'll buy one and fab up some kind of bracket/ recess for it. Cheers.
Old 09-07-21, 08:08 AM   #10
SV650rules
I don't think the fan on my AL7 has ever turned on, despite having a perforated guard in front of radiator reducing the airflow, the temp gauge is rock steady.
2016 SV650 AL7
Engine temp goes up and down chris c Bikes - Talk & Issues 5 31-07-13 07:42 AM
Oil Temp, Engine Temp and Rad Temp Owenski Bikes - Talk & Issues 0 30-06-11 09:36 AM
engine temp avvacuppa SV Talk, Tuning & Tweaking 7 13-09-08 07:37 PM
Engine Temp Help jonhunt SV Talk, Tuning & Tweaking 3 01-01-06 05:59 PM
engine Temp K4/K5 jonhunt Bikes - Talk & Issues 2 14-08-05 02:45 PM
