Old 21-10-21, 01:04 PM   #1
guffers_hump
Junior Member
Default SV650 1999 best cam chain tensioner
Hello,
I will be picking up a SV650s very soon and it will need the cam chain tensioners doing.
Which ones should I buy? Does it even matter as long as they are meant for mk1 SV.
Will these do?
https://www.ebay.co.uk/itm/163551597941
guffers_hump is offline   Reply With Quote
Old 21-10-21, 02:22 PM   #2
Default Re: SV650 2000 best cam chain tensioner
what makes you think it needs new camchain tensioners?
Old 21-10-21, 03:45 PM   #3
guffers_hump
Junior Member
The previous owner of the bike says that they need doing. I am going to buy the Tensioners and he is going to do them as I am getting the bike for free.
Old 21-10-21, 05:06 PM   #4
Originally Posted by guffers_hump View Post
Hello,
Will these do?
From what I've read, don't bother with mechanical ones, just get 2nd gen ones for yours. But I'd get them checked, as Bib's says why do you need new ones?
Can'r remember the part number, but a Google should tell you which ones
Old 21-10-21, 08:23 PM   #5
johnnyrod
johnnyrod's Avatar
K3 ones go straight on and are roughly 10000000000000% up on the originals. You'll need the gaskets as well.
Old 22-10-21, 08:25 AM   #6
guffers_hump
Junior Member
I got mixed up its a 1999 model not a 2000.
Is this the correct one then. It says its K3.
I assumed all the carb models were the same.
https://www.fowlersparts.co.uk/parts...2811-17G01-000
Old 22-10-21, 09:50 AM   #7
the K3 tensioner is a direct swap for the older ones which are known to jam. its rare though that they do jam and if the engine is noisy then i would also look elsewhere. i suppose if the bike is free then no harm doing the job.
SV's do not like low oil levels and is the number one engine killer on these bikes so keep an eye on the oil level. also if you overfill with oil the gearbox tends to give a lot of false neutrals and difficult gear changes.
Old 22-10-21, 12:45 PM   #8
guffers_hump
Junior Member
I've bought the K3 ones.
I'll keep an eye on oil level when I have the bike. The previous owner has had the bike for 15 years at least.
Has also been riding and fixing bikes since the 70's. So fingers crossed he knows what he is doing.
Thanks for the help.
Old 22-10-21, 08:33 PM   #9
johnnyrod
johnnyrod's Avatar
Might be the wrong part no. I've got 2003 ones in my 99 650
https://www.cmsnl.com/suzuki-sv650-2...l#.YXMf3rvPxnI
Where to get a Cam Chain Tensioner? turlock SV Talk, Tuning & Tweaking 4 22-01-11 11:44 PM
cam chain tensioner jimmy SV Talk, Tuning & Tweaking 2 21-06-09 02:27 PM
Help need a cam chain tensioner freebird SV Talk, Tuning & Tweaking 25 29-09-08 12:18 PM
sv650 cam chain tensioner sottondan SV Talk, Tuning & Tweaking 1 24-06-08 10:45 PM
Cam chain tensioner. Stig Stuff Wanted 8 11-12-05 06:14 PM
