Old 02-03-22, 06:31 PM   #1
johnnyleitrim
Junior Member
johnnyleitrim's Avatar
Default Clock losses time
So I bought a 2018 SV650 last week. I set the clock to the correct time this morning, but when I started up the bike a few hours later, it hadn't kept time - the time was only a hour later than what I had set in the morning.
The rest of the electrics all seem fine, so I'm assuming the battery is fine. Has anyone had this issue before?
johnnyleitrim is offline   Reply With Quote
Old 02-03-22, 09:01 PM   #2
Seeker
Seeker's Avatar
Default Re: Clock losses time
No, not seen nor heard of it, I'm guessing operator error. Once you had the time set did you press and hold the SEL and ADJ buttons together for 2 secs to save the value? If you didn't and just switched off it would revert back to its previous setting.
2016 SV650AL7
2023 GSX-8S
Old 02-03-22, 09:21 PM   #3
johnnyleitrim
Junior Member
Ah, that would be it - I did just turn it off after setting the time. I'll try again tomorrow but definitely sounds like operator error alright!
What time is it? Clock always resets. r_bacon SV Talk, Tuning & Tweaking 6 09-01-12 01:55 PM
time clock dave SV Talk, Tuning & Tweaking 1 08-03-09 10:29 AM
wrong time on forum clock neio79 Idle Banter 4 13-04-07 02:33 PM
Time Clock Adjusting 600+ SV Talk, Tuning & Tweaking 2 07-09-06 07:59 AM
What clock do you use on the bike (to tell the time) SpankyHam Bikes - Talk & Issues 52 05-06-06 10:15 AM
