Old 09-03-22, 08:07 PM   #1
Default Temporarily sealing brake hoses
I need to strip and clean my calipers. Anyone got any good tips to keep as much fluid in the brake lines as possible while I do it?
Old 09-03-22, 08:29 PM   #2
Adam Ef
Adam Ef's Avatar
Default Re: Temporarily sealing brake hoses
Sounds obvious but gravity is the only chance you have. Get the calipers high up before you remove them. I imagine you'll end up with some air in the lines anyway and have to flush all the fluid through to push it out. I'd just accept that it will happen and drain the fluid.
Past:
Old 09-03-22, 08:31 PM   #3
DJ123
DJ123's Avatar
Is it an issue if they empty (i'm thinking ABS pumps and air locks)?
i would raise the end of it as high as you can (keeping the open end facing vertical) to remove any gravitational pull and reduce head height pressure. And use some rag/blue towel over the end as it shouldn't absorb too much, and secure it with a cable tie, or gaffer tape.
BMW F800ST
Old 09-03-22, 08:45 PM   #4
Adam Ef
Adam Ef's Avatar
If it has ABS then yes, it can be.
Depends on the bike but often you'll need the diagnostics software and interface to activate the ABS pump and use it to pump fluid through and bleed it. I know Triumphs can be done with the aftermarket "Dealertool" software and dongle which is cheaper at £65 than OEM software and interface. OEM devices are normally prohibitively expensive. In theory you could ride the bike and try to get the ABS to activate as much as possible to push air out, but that would be one hell of a ride and not sure it would be totally successful.
Past:
Old 09-03-22, 09:05 PM   #5
Yeah it's got ABS. I've never bled a bike with ABS before so I'm not looking forward to it!
It's an Aprilia Dorsoduro if it makes any difference
Old 09-03-22, 09:22 PM   #6
DJ123
DJ123's Avatar
In which case, i wouldn't let the lines bleed out. Not unless you have a tool to pump the ABS module to help bleed the entire system.
The main thing is not to let the line between the MC & module go dry. If it's the line from the pump to the callipers, you'll be fine as no air has entered the ABS system.
Thinking about it, you could use some mole grips on the brake line (not hard) enough to reduce the flow of fluid and prevent them bleeding as quick. And with them raised that should help to slow the flow further.
BMW F800ST
Old 09-03-22, 10:09 PM   #7
Adam Ef
Adam Ef's Avatar
Don't drain the system if it has ABS. Do as you planned and try to keep as much fluid in the lines and then bleed the standard lines as normal to fill the calipers. Should be ok.
Past:
Old 09-03-22, 10:20 PM   #8
admin
John T
admin's Avatar
Car mechanics often use a clamp on the hose. I can't say I've ever used one on a bike though.
Old 09-03-22, 10:22 PM   #9
Thanks guys. I'm thinking raise them up like you say and putting a normal bolt in with the old washers just in case
Old 09-03-22, 10:22 PM   #10
I really don't like the idea of a clamp, especially on braided lines
Fitting brake hoses, Really?! Toooldtodie SV Talk, Tuning & Tweaking 17 02-09-15 08:34 PM
Brake hoses Aldoo SV Talk, Tuning & Tweaking 2 28-02-15 11:22 AM
Are these brake hoses on the right way? 5hort5 Bikes - Talk & Issues 12 24-01-10 02:35 AM
Brake hoses. Pam SV Talk, Tuning & Tweaking 13 09-09-08 02:55 PM
Hel Brake Hoses kevbuck SV Talk, Tuning & Tweaking 23 22-12-04 01:31 PM
