Old 17-01-24, 05:31 PM   #1
Brianoc
Junior Member
Default K4 Dash Change
Hi,
I want to swap the dash on my race bike...BUT...The gear position indicator is reistance based as standard which after market dashes basically don't do..
So, I'm wondering if anyone has managed to buy or make a switch that energises a specific wire based on the resistance "felt". Most of the dashes I have want a voltage on a spcific wire to indicate the gear so the switch as described would do the trick
I also have some chinese gear postion indicators Which look like they will fit (They were advertised as SV650) but no wiring diagram to hitch things up - Has anyone got one ??
Thanks in advance,
Brian
Brianoc is offline   Reply With Quote
Old 18-01-24, 11:44 AM   #2
Seeker
Seeker's Avatar
Default Re: K4 Dash Change
I don't know if this helps...
https://www.svrider.com/threads/gear...ltages.116723/
I found it whilst idly googling (a bad habit). D'Ecosse produces a lot of electronic info for the SV although he's now a Triumph devotee.
2016 SV650AL7
2023 GSX-8S
Old 18-01-24, 01:52 PM   #3
Brianoc
Junior Member
Cheers !!
Dash Dim? liamstears SV Talk, Tuning & Tweaking 1 24-11-16 09:45 AM
TT - Another Mad Dash yorkie_chris Idle Banter 38 30-12-11 02:24 PM
Mad Dash to the TT Luckypants Photos 30 28-12-11 01:59 PM
FI on dash gary sv SV Talk, Tuning & Tweaking 20 16-02-09 02:12 PM
The Dash Ward8124 East Anglian Revolution 0 20-08-07 06:28 PM
