Old 12-07-24, 06:21 AM   #1
Seeker
Seeker's Avatar
Default Random carb question
Someone on the US forum has a curvy that won't idle below 4k rpm and it got me thinking (a rare occurrence). If you wind the throttle stop adjuster to give a 4k rpm idle is it still running on the carb's pilot circuit?
I didn't think it would be but I was visualising a non-CV carb where the throttle stop would lift the slides and thus pull the needle higher.
On a CV carb at 4k rpm with no load, the vacuum would be high so would that lift the slides/needle in the same way?
2016 SV650AL7
2023 GSX-8S
Old 13-07-24, 11:31 AM   #2
NedSVS
Default Re: Random carb question
I think that even on a non-CV carb, that at 4k rpm, the venturi effect would be enough to draw fuel from the needle/needle jet clearance; surely, they must have blocked pilot jets?
Old 14-07-24, 11:15 AM   #3
R1ffR4ff
R1ffR4ff's Avatar
Here's a really good video explaining how CV carbs work,
https://www.youtube.com/watch?v=IBFq9nHVmks&t=1s
Old 14-07-24, 04:14 PM   #4
redtrummy
Video not available anymore
redtrummy is offline   Reply With Quote
Old 14-07-24, 05:06 PM   #5
R1ffR4ff
R1ffR4ff's Avatar
I've changed it to a link,
Old 14-07-24, 07:45 PM   #6
redtrummy
Thanks R1FF
Random question of the day! daveyrach Idle Banter 9 27-06-13 03:00 PM
Random question.. bathwiggle East Anglian Revolution 2 09-02-13 08:40 PM
random x box 360 question etuna Idle Banter 13 01-11-08 08:46 AM
Random question for the IT bods... Baph Idle Banter 6 23-10-08 09:30 PM
Just a random question ljharmitt Idle Banter 23 21-01-07 07:28 PM
