Old 30-07-24, 06:43 AM   #1
cocksey
Junior Member
Default Fuel pump
Good morning all. I have a Cagiva 650 Raptor (SV 650 really) !!! The dreaded E10 fuel pretty much destroyed the original pump after winter storage. I sourced what on visual inspection looks like a really clean unit, but, once fitted it allows fuel to pass even before the power is connected. Does this mean the pump is at fault ? Or is it me being thick ?!!? The pump was purchased from E-bay, unfortunately the seller is away until 10/08/24, so obviously I cannot do much until then, regarding returns. Hoping some clever bugger can tell me either way, I'm fairly competent on the spanners, and do not think its me ! A new pump is the best part of £1k !
cocksey is offline   Reply With Quote
Old 30-07-24, 11:42 AM   #2
glang
Default Re: Fuel pump
Yes I wouldnt have though fuel should run through as the drawing in the free online workshop manual shows a spring loaded non return valve in the outlet which should need some pressure to overcome before fuel comes out...
Old 30-07-24, 12:02 PM   #3
R1ffR4ff
R1ffR4ff's Avatar
Check the US forum. There are several posts on rebuilding the pumps and or some of the cheaper Alternatives,
https://www.svrider.com/search/27743...mp&o=relevance
Old 30-07-24, 01:36 PM   #4
glang
Just thought if you can blow back in through the outlet theres definitely a problem...
Old 30-07-24, 06:32 PM   #5
cocksey
Junior Member
Thanks
Old 30-07-24, 06:48 PM   #6
cocksey
Junior Member
Well i can blow back through the outlet !
Old 30-07-24, 06:51 PM   #7
cocksey
Junior Member
2008 SV650 Fuel Cap/Fuel Pump jwray4422 SV Talk, Tuning & Tweaking 3 26-06-18 06:27 PM
Fuel pump change Tomcatracing SV Talk, Tuning & Tweaking 3 27-07-10 07:31 AM
How do i remove the fuel pump on a K5 tonny006 SV Talk, Tuning & Tweaking 10 01-10-08 08:45 PM
Fuel pump cornishrider SV Talk, Tuning & Tweaking 6 02-03-08 07:25 PM
K5> fuel pump phil24_7 Stuff Wanted 11 29-10-07 05:18 AM
