Junior Member
My machine blew over in high winds. However, the R/h fairing will need removing and repainting. I have removed the self tapping screw and 4mm Allen bolt at the bottom of the fairing. Removed the 4mm Allen bolt that is in the middle of the fairing. Loosened the 3 x 4mm Allen bolts at the top of the fairing. BUT the panel itself does not feel loose. Are there more fasteners to loosen elsewhere?
I have also got to replace the front brake lever. Is that an easy task. All said and done. I have got off quite lightly really. Last edited by Crank090865; 13-10-24 at 09:48 AM. |
If this is the factory fitted lower then mine has a plate with plastic rivets right underneath that joins each side together. You have to pop out the centre pin in each and then the rivet body comes out - quite fiddly actually...
The brake lever should be easy: From memor, take off the lock nut nut he bottom of the piyot bolt the unscrew the pivit bolt itself and the lever will slide out from the housing. Refitting is reverse of removal.
(Can't help you about the faieing because I don't run a faired SV.)
Spannering the wife's SV650S K5 pointy in Black, and son's SV650 X curvy in Blue. RIP SV650 X curvy, crashed and written off December 2019. I'm (procrastinating about) fixing up an old Yamaha FZ600 to get myself fully back on the road. |
Replacement Folding Brake Lever For Brembo Master Cylinder | Stuart42 | For Sale - Other Bikes and General biking items | 1 | 23-01-16 05:45 PM |
r/h red fairing (curvey) r/brake lever..... | SUPERSTARDJ01 | Stuff Wanted | 1 | 30-10-09 07:48 PM |
Replacement Brake Lever - fairly standard fits? | schofs | Bikes - Talk & Issues | 7 | 09-11-08 10:52 AM |
SV650s K3 brake lever | K2 | Stuff Wanted | 0 | 06-03-07 05:09 PM |
Replacement Front Brake Lever | bobit69 | SV Talk, Tuning & Tweaking | 1 | 31-05-05 09:16 PM |
