Old 15-02-25, 05:33 PM   #1
DamoK4
Default Starting issue
Hi guys. I have just tried to fire the bike up after being in the garage all winter and it wouldn’t fire. The battery had died as I forgot to leave it plugged into the trickle charger, so I left it on again for a week and no joy. I just changed the battery for a new one and it still wouldn’t fire, just a single click. When I undid the heated grips and the trickle charger it fired up straight away and was fine. Do you think this is a fuse issue? Or is having 3 things contacting the battery causing it? The garage fit my last battery when I put the r1 shock on the back as it needed the battery box moving up and a smaller battery fitting. One of the grips didn’t work after that either. Sorry for the long write up! It’s a 2004 pointy
DamoK4 is offline   Reply With Quote
Old 15-02-25, 08:22 PM   #2
garynortheast
garynortheast's Avatar
Default Re: Starting issue
I take it the heated grips weren't actually switched on when you tried to start the bike?
Blue Curvy S with nearly 110,000 miles and still going strong.
Old 15-02-25, 11:16 PM   #3
DamoK4
No they were off. They only have + and - buttons.One of the grips didn’t work after changing my bars when I had a riser kit installed come to think of it, was quite a while ago now so that’s probably unrelated
Old 16-02-25, 08:18 AM   #4
garynortheast
If it wouldn't start with grips and charger connected I'd be starting there, particularly if one of the grips doesn't work. I'm wondering if there's a short circuit there, robbing the battery.
Old 17-02-25, 12:21 PM   #5
R1ffR4ff
R1ffR4ff's Avatar
I agree with Gary. It might be best for now to remove the grips and their wiring as it's starting to warm up into Spring. If then the bike runs OK you can address the grips problem later
R1ffR4ff is online now   Reply With Quote
Old 17-02-25, 02:30 PM   #6
DamoK4
Cheers guys I’ll leave them off. If one isn’t working I suppose they are pointless anyway.
Starting Issue curvy hindle8907 Bikes - Talk & Issues 10 10-07-13 02:49 PM
Starting issue - K3. Badeye Bikes - Talk & Issues 1 17-01-12 12:47 PM
GSX starting issue keltoi Bikes - Talk & Issues 6 09-05-10 09:29 PM
starting issue AndyBrad SV Talk, Tuning & Tweaking 58 23-04-09 08:12 PM
Help - Starting issue or lack of Pingu65 Bikes - Talk & Issues 3 28-12-08 12:23 PM
