Old 11-03-25, 09:22 PM   #1
tactcom7
Junior Member
Default Project SV
Figured I'd start a separate thread rather than continuing to spam Idle Banter.
Pics show the bike in bits, the rather interesting situation of the oil pressure sender having been replaced by a bolt, and the tope yoke once I'd (nearly) finished modding it.
I'm looking to powder coat the frame/tank and swingarm, probably paint the engine and take it from an S to a naked.
I imagine I'll keep the suspension stock, don't want to throw too much money at it.
Thanks for looking.
tactcom7 is offline   Reply With Quote
Old 12-03-25, 08:54 AM   #2
garynortheast
garynortheast's Avatar
Default Re: Project SV
Be interesting seeing this project progress. Good luck with it all!
Blue Curvy S with over 110,000 miles and still going strong.
Old 12-03-25, 09:16 AM   #3
Craig380
Keep us posted with progress. I was reading an old bike mag last night which had a feature about compact supercharger kits for bikes, just sayin' ....
Old 12-03-25, 09:21 AM   #4
tactcom7
Junior Member
Cheers, it'll probably end up looking something like my old one, minus the GSXR front end and ZX7 rear shock. Oh and hopefully no dent in the tank...
File Type: jpg Screenshot_20240510_201612_DuckDuckGo.jpg (97.1 KB, 0 views)
Old 12-03-25, 04:54 PM   #5
tactcom7
Junior Member
Well in today's edition of what in the actual...
Decided I'm going to powdercoat the front fork lowers, so, for the first time I started stripping them.
Imagine my surprise when I found a 24mm socket underneath the top nut of the right fork, and a 23mm socket under the left one. It's my first time stripping suspension so, and I can only guess, this compresses the spring more for a stiffer ride??
On top of that, I've got a 2002 bike which has the 2001 Top Nut (item 1), but each fork also had the top spacer thingy (Item 22) fitted. So it seems to be a mish mash, which doesn't surprise me considering the state of the rest of the bike.
Any ideas?
Thanks.
Old 12-03-25, 06:19 PM   #6
glang
A lot of people make this mistake and think preload, whether with spacers or screw adjusters, does something to the spring and ride! Wrong, all it does is raise the bike height and the spring stays exactly as before
Preload is purely to adjust the height of the bike for different loads so for example with two hefty riders plus luggage the springs will compress a lot and the dampers will be too near the end of their travel and risk bottoming out. Using preload the springs will still be compressed as before but the dampers can be pulled up so they sit in the correct position to leave approximatelty 2/3 of down travel - this is called setting the sag
Old 13-03-25, 10:03 AM   #7
tactcom7
Junior Member
Thanks for the explanation! At least I have two more sockets to add to my collection. I'm still slightly confused by the apparent mixing of parts, old style top nuts but a K2 spacer. Oh well I shall rebuild them minus the sockets and see how it feels.
Thanks again.
Old 30-03-25, 06:12 PM   #8
tactcom7
Junior Member
Never had a mudguard on the old SV so, I decided to grind off the mounting lugs pre powder coating (1 done in the pic). Might regret it later, especially if it rains but we shall see
Old 03-04-25, 09:28 AM   #9
garynortheast
Ha ha! I'll be interested to see how you feel about that after you get caught in the rain and have to clean the front of the bike off!
Any more progress on the project?
Old 03-04-25, 11:31 AM   #10
I'm pretty sure that there are supposed to be metal spacers in with washers there where the sockets are. Most folks just use plastic plumbing pipe cut down to get the ride height right. If you know s welder get the rebound holes welded up.
Sv 650 project for somebody maybe? Booka For Sale - SV's and SV related items 6 21-04-15 05:21 AM
My new project mister c Photos 121 06-07-12 02:54 PM
help with uni project TeddyBearKing Idle Banter 20 17-04-09 06:33 PM
gpx project Airwolf SV Talk, Tuning & Tweaking 1 19-08-08 08:49 PM
What 'project' for £100 glade Bikes - Talk & Issues 20 24-10-06 07:19 PM
