Old 22-03-25, 08:47 PM   #1
Lewis82
Junior Member
Default K3 suspension
Recently had some work done on my bike. At ~35k miles and having owned it 2years I had the fork oil and seals changed. Asked the mechanic if he noticed anything non-standard about the springs. He mentioned some scoring on the tube which he sanded down and isn't concerned about and a previous owner (1of 5 or 6) added some shims. Any ideas as to why they'd be added? What would be the next step to upgrade for street use? It has a nitro r1 rear shock but nothing up front so will look at changing those.....later down the line.
Tia
Lewis82 is offline   Reply With Quote
Old 23-03-25, 09:50 AM   #2
admin
John T
admin's Avatar
Default Re: K3 suspension
I guess the shims were added to increase preload on the springs. A common upgrade is to swap the front-end to a GSXR setup, better brakes too.
Old 23-03-25, 10:40 AM   #3
Lewis82
Junior Member
Do you increase pre load by screwing the adjustment screws on the forks down? As they're very far out on mine
Old 23-03-25, 01:17 PM   #4
garynortheast
garynortheast's Avatar
Which model of SV is it?
**Edit** I'm a dunderhead - it's in the post title. Doh!
Blue Curvy S with over 110,000 miles and still going strong.
Old 23-03-25, 01:17 PM   #5
GeorgeRYoung
https://web.ncf.ca/ag136/SV650Gen2/Y...Emulators.html
65 CB160 (67-69), 69 350GTR (69-72), 72 R5, 73 RD350 (73-84), 82 XZ550 Vision (84-03), 01 Concours C10 (03-19), 89 EX250 (11-14), 00 SV650S (14-16), 03 SV650S (19-)
GeorgeRYoung is offline   Reply With Quote
Old 23-03-25, 01:30 PM   #6
glang
Increasing preload is only used if the weight on the bike (people and luggage) is upsetting the height of the bike. Unfortunately it does nothing to spring strength or any other suspension parameter Even then a lot of people find the springs too weak for the weight carried so fitting the correct ones is a prime consideration...
Old 25-03-25, 01:40 PM   #7
Setting preload without rider determines if the bike needs springs suiting rider weight. Can't remember off hand what the measurements are but it goes like...
Set your preload without rider.
CHECK preload with rider on bike.
If the measurements fall out of spec with rider on bike then you need to get new springs. If the bike is used for street dont use settings for racing.
Old 25-03-25, 02:18 PM   #8
glang
Yes basically with bike fully loaded your suspension should sit about a third of the way down its travel. A lot more than this and stronger springs are required...
Suspension overhaul: MCT Suspension Stowmarket. Dicky Ticker Bikes - Talk & Issues 11 01-08-10 11:18 AM
Suspension - again - sorry!! pencil shavings SV Talk, Tuning & Tweaking 11 25-05-08 11:26 AM
suspension when 2 up Draper SV Talk, Tuning & Tweaking 5 08-05-08 10:27 AM
suspension ljharmitt SV Talk, Tuning & Tweaking 5 07-11-07 08:02 PM
Suspension set up Mike2165 SV Talk, Tuning & Tweaking 2 15-09-07 02:03 PM
