Old 03-04-25, 07:25 PM   #1
Lewis82
Junior Member
Default Getting rid of clip ons....🤔
Attached should be some pics of an item on Ebay. Says that these can be bolted to top of forks if there's 25mm showing through current standard setup (at least that's how I think it's meant to be) which should enable me to get rid of clip ons and add proper bar (obviously I'll need to reroute brake cables or buy naked ones.
Anyone seen these before? Do they look OK?
Can't find a cheap enough conversion and I'm sick of thr clip ons
Tia
Lewis82 is offline   Reply With Quote
Old 03-04-25, 08:05 PM   #2
garynortheast
garynortheast's Avatar
Default Re: Getting rid of clip ons....🤔
I would have thought that having 25mm of fork showing through the top yoke would mean the front of the bike is much lower than it should be, and would alter considerably the geometry and subsequent handling characteristics of the bike. You may be better off stumping up for a proper comfort kit, or finding a second hand naked SV top yoke on which to mount normal handlebars.
Blue Curvy S with over 110,000 miles and still going strong.
garynortheast is online now   Reply With Quote
Old 04-04-25, 07:22 AM   #3
glang
Yes you could possibly correct some of the drop at the front of the bike by increasing fork preload but its a bit of a gamble...
Old 05-04-25, 11:30 AM   #4
If that yoke is for a pointy 2003 to 2012 ish it wont fit as the ignition position is wrong. If its a curvy then it should be fine
Old 05-04-25, 02:03 PM   #5
glang
I think you only get the raisers shown in the first pic and the second is just an illustration of their installation...
Old 06-04-25, 11:35 AM   #6
admin
John T
admin's Avatar
Some people installed Helibars but they're not cheap either.
As Gary said earlier, it might be cheaper to buy a used top yoke off a naked SV from eBay.
Old 14-04-25, 06:18 PM   #7
Jayneflakes
Jayneflakes's Avatar
An acquaintance of mine, some years back, took his top yoke off and welded a set of risers to it, so that he could fit a Renthal Bar. I have no idea what this did to the top yoke, but it did look pretty. He was also one hell of a welder, which probably helped.
On my bike, the top yoke is modified and has machined aluminium plugs that were epoxy bonded (with some posh engineering glue I recall!) into the back, so that I can have custom risers for my Renthal bar. Neither option is cheap, but needs must when the devil tries to stick a rod up your bottom!
Jayne you're a Pussy Magnet
Clip ons Taylor1975 SV Talk, Tuning & Tweaking 3 24-03-08 02:39 PM
K3 S clip ons flymo Stuff Wanted 1 01-03-08 04:19 PM
Clip ons markmoto Stuff Wanted 4 19-07-07 09:01 AM
Clip-ons....(from flat bars to clip-ons) Gnome SV Talk, Tuning & Tweaking 6 12-07-07 06:57 PM
clip on for a k3 rafcc SV Talk, Tuning & Tweaking 0 13-03-07 11:45 AM
