Old 16-10-04, 05:24 PM   #1
bzh
Default adaptation forks of GSX-R on my SV650
I would like to adapt a before suit of GSXR with pitchfork, braking and wheel but I would like to know how to make ???
i don't know what "tés" of pitchfork to choose: for GSXR or for SV ?
thank you very much for your advice and your photos if you have some
Old 16-10-04, 05:42 PM   #2
bzh
Originally Posted by 21QUEST
can you help me ???
Old 16-10-04, 10:51 PM   #3
I've not done this, but I've read those who have... There's a guy on SVrider.com's forum called TWF that makes a bearing that you can fit to allow a GSXR front end to bolt to the SV's steering stem. Otherwise, you need to machine or braize one of your parts as the bearings are different.
Old 17-10-04, 12:26 AM   #4
21QUEST
21QUEST's Avatar
Nortwind is right about the TWF in the US. The other way is to press out the SV Stem and press it into the GSXR bottom yoke. For the GSXR top yoke you need to make spacer to fit inside the hole where the stem goes through as the SV stem is a smaller diameter than the GSXR stem. Doing it that way means you can get the bearings straight off the shelf if you ever need to change them. I think it cost me about £50 to get done.
What year GSXR are you looking at using. I'll try and sort some photos out for you (don't hold your breath though ).
Ben
Nemo me impune lacessit.
Old 17-10-04, 10:40 AM   #5
bzh
thanks.
Old 17-10-04, 10:41 AM   #6
bzh
I'll try and sort some photos out for you.
thank you Ben
Old 31-10-04, 12:36 PM   #7
ARAF
I have a GSXR750 SRAD front end on my K1 SV.
The SV stem had to be built up with weld, and then machined back to the correct taper for the GSXR bottom yoke.
SV head bearings are used top and bottom.
Araf
SV650 with GSXR forks £1000!!! carsounds_dan For Sale - SV's and SV related items 15 11-06-09 07:51 PM
Forks for SV650 99 philbert SV Talk, Tuning & Tweaking 2 30-09-08 05:40 PM
Need some information on SV650 Forks katana SV Talk, Tuning & Tweaking 5 26-01-06 07:23 PM
usd forks for sv650 naked riktherider SV Talk, Tuning & Tweaking 6 15-04-05 09:37 PM
RGV250 forks on SV650? snoopy SV Talk, Tuning & Tweaking 71 20-01-05 11:12 AM
