Old 16-10-04, 10:05 PM   #1
Quiff Wichard's Avatar
Default paddock stands
just got a paddock stand today so i can do me chain easier-- maybe shudda got a scottoiler!!
anyway - wot a pain !!.
it is the type with the cups to sit under the swinging arm.
where should I site them- right at the back?? when I do then the sprocket bolts hit the cup?
further down and the brake pipe gets in the way ..
my bike has bobbins onalready so wud it b best to get a bobbin kit and use those?
Old 16-10-04, 10:31 PM   #2
Rodger Wabbit
Hi iv got a paddock stand to, and i found the best place to fit it is just by the brake pipe. Even though it looks like its hitting the brake pipe it dosent. It will just push the brake pipe away slightly but the pipe should have plently of slack to go around.
Old 16-10-04, 10:58 PM   #3
Fiddly things aren't they? I got fed up playing with mine and got an Abba as well. I was always tangling the stand with the chain and torque arm...
Old 17-10-04, 10:48 AM   #4
svpilot
Hi,
Is it the micron padock stand? Invest in the 'bobbin' kit. Makes things a lot easier/more secure.
If you do invest in a bobbin kit here's a top tip: find a piece of hose pipe or plastic conduit to set the spacing for the 'hooks' you will see what I mean if you get the kit.
HTH
Old 17-10-04, 10:55 AM   #5
jonboy
Default Re: paddock stands
No not right at the back in case they slip off. It's a little tricky but maneouvre the cup on the righthand side so that it's forward of the axle bolt and above the brakeline. Similarly on the lefthand side, forward of the axle and wiggle it in above the bottom length of chain.
Once you've done it a couple of times you'll get the idea. Without a doubt, bobbins have to be easier.
Old 17-10-04, 12:09 PM   #6
rictus01
rictus01's Avatar
Hooks & bobbins, one handed operation.
Cheers Mark.
Old 17-10-04, 12:15 PM   #7
wheelnut
Although not paddock stand chat, maybe the readers of an ilk will help.
I saw a belt drive conversion kit for an SV650 but I lost the advert.
I think it was a Swiss company or maybe German
1. did you see it
2. would it work?
3. would it be worth it?
4. plusses and minuses please
Old 17-10-04, 12:19 PM   #8
cheers guys-
ta john i had a go this mornin and it is a lot easier...
I ran a post a while back b4 buying one askin if they are easy or fiddly to use and on the back of a mixed response i got one ...
maybe i shudda just bought a scottoiler !!!
Old 17-10-04, 12:32 PM   #9
rictus01
rictus01's Avatar
1. did you see it
2. would it work?
1. no
2. not as weel as a chain
3. no
4 half way house to a shaft drive
Funnily enough I was looking at this the other way around, and the kits to change a Buel from belt to chain,because dispite the dealer saying the belts are good for 30k or so, no-one who uses them expects anything over 10k, and buys another belt about then.
Cheers Mark.
Old 17-10-04, 02:12 PM   #10
bzh
look at that : http://www.ps-performance.com/boutiq...?cPath=994_423
It's a frienf of mind, senf a mail to Saïd : contact@ps-performance.com : nice price !!!
Paddock stands davidimurray Ancillaries 53 22-12-07 05:27 PM
Paddock Stands shelleyamy Stuff Wanted 0 26-06-07 01:51 PM
paddock stands muffles SV Talk, Tuning & Tweaking 14 15-05-06 04:28 PM
Paddock Stands swordtail SV Talk, Tuning & Tweaking 21 30-08-05 11:55 PM
Paddock Stands rob13 Bikes - Talk & Issues 5 04-07-05 07:57 PM
