Old 25-10-04, 02:20 PM   #1
snoopy
Default LED Indicator Bulbs
Hoping someone can help me on this. I want to replace the indicator bulbs with LED versions. Will these do...? http://cgi.ebay.co.uk/ws/eBayISAPI.d...sPageName=WDVW
Secondly I know they're going to flash to fast. I wish to find the flasher unit and build a new one. Is this the black box at the back of bike further back under rear seat??
Old 25-10-04, 07:42 PM   #2
BURNER
The flasher unit is not under the rear seat that's your ignition box. Flasher uinit is much smaller and down near the battery 2 pin or 3 pin can't remember which coz All I've done is clean mine.
Old 25-10-04, 09:32 PM   #3
snoopy
Right thanks, anyone know if these bulbs will fit?
I'll design a circuit and post here if anyones thinking of ditching the parallel resistors. Will comprise of two transistors, couple resistors and capacitors. Very easy.
Old 25-10-04, 10:00 PM   #4
Haircut
Haircut's Avatar
Sounds like an astable multivibrator to me!
DOH!
Haircut is offline   Reply With Quote
Old 25-10-04, 10:29 PM   #5
snoopy
Got it in one
Old 26-10-04, 11:14 AM   #6
PBx
Yes please. I think its the only way of getting reasonable performance.
Old 26-10-04, 11:32 AM   #7
The flasher unit is under the riders seat and is, bizarrely, incorporated into the ignition cut out relay.
Old 26-10-04, 05:06 PM   #8
snoopy
I'll have to try and get a schematic then.
Old 28-10-04, 02:21 PM   #9
snoopy
I had a look at the flasher unit today. It's a simple relay flasher. The good part is I can use the same housing, new circuit board and same connectors to create an identical plugin unit. The problem is the circuit board within the flasher unit has been glued in heavily. I'll have to find a way to get rid of that glue.
Indicator Bulbs, help! injury_ian Bikes - Talk & Issues 3 29-03-07 08:40 PM
Indicator Bulbs Stormspiel Bikes - Talk & Issues 4 25-05-06 07:40 AM
led indicator bulbs ophic SV Talk, Tuning & Tweaking 1 09-03-05 08:50 PM
LED Indicator bulbs the oaf SV Talk, Tuning & Tweaking 8 06-12-04 10:08 PM
Indicator Bulbs stillnoname Idle Banter 3 07-01-70 11:52 AM
