Old 03-12-04, 04:41 AM   #1
Pierre86
Default Sport to Standard Conversion ?
Is it possible to convert a SV650s to the SV650 standard version ?
Is it possible on pre and post 2003 models ?
Is it high priced and a lot of work ?
I wouldn't want to only take off the fairing, but having the round headlight and the Standard's handlebar...are there any other differences between the two models ?
Thanks for your anwsers and advices !!
Pierre
Old 03-12-04, 08:16 AM   #2
rictus01
rictus01's Avatar
well on the classic shape,
Clocks are different,
the clock mount is different,
front loom splits into two for the clocks (not a single multi plug),
cables (throttle &clutch) are longer,
top yoke is different,
handle bar mounts for both levers have mirror mounts on them,
seperate mounting for the headlight,
front indicators would need mounting,
you'd need to make sure you got a headlamp with sidelight in it (as you'd loose yours),
you'd also be left with the fairing mounts on the ends of the rad.(also no screw threads to fix the rad end trim to).
Just about all I can think of now.
Cheers Mark.
Old 03-12-04, 08:19 AM   #3
It can be done, you'll need the top yoke from the unfaired, or possibly you could drill the yoke you have and fit 'bar clamps, removing the fairing is easy enough, but you may well find unfaired clocks for the early shape bikes hard to come by, K3 on have the same clocks faired and unfaired, but the holder is different obviously. There are plenty of aftermaket headlamp brackets, and headlights too, again the unfaired lights are not that common secondhand.
It may well be cheaper in more than one way to sell the bike you have and buy an unfaired, when you're done with it, it will certainly have better resale value as a standard bike.
Old 03-12-04, 11:48 AM   #4
Ceri JC
Default Re: Sport to Standard Conversion ?
Just an idea, as the S is more expensive (albeit more common) it might be worth looking for someone with a similar year/model naked one to do a swap with?
Old 04-12-04, 11:10 PM   #5
Pierre86
Thanks for the advices !
The thing is, i'm in Canada, and 2004 is the first year they import Standard version, so there won't be any affordable secondhand bikes for the next few years. I haven't buy any bike yet, but I'd really prefer the Standart to the Sport version...anyway, thanks a lot !
Pierre
Old 07-12-04, 03:36 PM   #6
mikemm
If you do decide to do it, I'd suggest keeping the faired versions speedo and revcounter because the rev-counter on the unfaired version looks like a tacked-on afterthought.
Standard Blue Sv 650 Sport K6 56 plate for sale 4000 miles £2600 in West Midlands davepugh1981 For Sale - SV's and SV related items 17 09-05-11 07:32 AM
Standard hugger from a K3 - K8 sport flymo Stuff Wanted 3 01-05-09 07:42 PM
m4a - mp3 conversion embee Idle Banter 17 04-06-07 09:22 AM
once again, the svs to sv conversion... littlewhitedaisy SV Talk, Tuning & Tweaking 33 24-05-06 03:51 PM
which air box conversion? Londonoz Exhausts 2 20-01-05 02:43 PM
