Old 22-12-04, 09:08 AM   #1
jasonsv61
Default electrical problem
Help please !!!
I removed the battery on my road going SV because it was dead and
then tried to start the bike by connecting the battery leads to my
car battery. The bike tried but just wouldn't turn over - and then
after a minute or so of trying to start the whole thing just died.
No lights, no nothing !!!
I've checked the fuses under the seat and all appear OK. Any ideas
on what I've managed to damage and how to fix it, PLEASE ??
Old 22-12-04, 09:14 AM   #2
Barty_b0y
Default Re: electrical problem
Originally Posted by jasonsv61
Help please !!!
Sounds like you`ve blown the main circuit fuse
this is located under a triangular moulding on the right of your bike under the seat unit ( removing the triangular moulding gives access to the seat screws )
thats where they at on a pre k3
you didnt say what model you have
Old 22-12-04, 09:34 AM   #3
jasonsv61
Thanks, I have the mouldings & seat off - but what does a main circuit fude look like ??
Old 22-12-04, 10:10 AM   #4
Mike1234
And to think you once raced the things!
At the front of the rear sub frameon the right hand side you should find a small plastic box with a green clip on cover. If you remove the cover there are two fuses, one is a spare (I think) and the other one is probably fried.
Old 22-12-04, 10:24 AM   #5
jasonsv61
Thanks, that's brilliant - I'll have a go when i get home this evening !!
Old 22-12-04, 08:35 PM   #6
jasonsv61
Dave,
I loctaed and removed the green cover as suggested, found only one fuse in place - 30amp - its was OK. So either there should be two and the other has dropped out - unlikely I would have thought, or its another problem. ANY MORE IDEAS ??
Thnaks,
JASON
Electrical problem DaveW SV Talk, Tuning & Tweaking 13 14-05-09 08:13 AM
Weird Problem, Electrical mister c SV Talk, Tuning & Tweaking 8 15-12-08 11:26 AM
Electrical problem drag Bikes - Talk & Issues 15 03-11-08 12:03 PM
Electrical Problem! BigB SELKENT 10 15-01-08 10:34 AM
SV electrical problem jonnyt SV Talk, Tuning & Tweaking 2 05-07-06 10:28 AM
