Old 23-12-04, 10:59 AM   #1
bikerskez
Default Fitting lower fairings
HELP Nothing i do is simple, i've managed to round off one of the nuts that i need to remove to fit the fairings, Somebody out there must have done the same, what did you do to get the bolt off?
Old 23-12-04, 11:00 AM   #2
Viney
Which bolt?
Old 23-12-04, 11:47 AM   #3
K
I would have guessed the one on the side stand - if only because I had trouble with that one.
Managed to get the bike up on a paddock stand on my own though which made it alot easier - less strain.
But thinking about it, that's an Allen Key job, rather than a bolt.
If it's the one under the radiator you can drill it out, as the replacement doesn't need the thread at the end as it goes straight on through (to be gripped the other side by a nyloc nut).
The one by the exhaust you may be able to hacksaw off. If you can, saw through the plastic/rubber washer - you'll obviously need to replace it, but it'll guide the saw blade through more accurately once your through the rubber.
Beyond that I'm not sure as I think the rest are the engine mounting bolts - which could spell trouble.
Old 23-12-04, 05:26 PM   #4
bikerskez
I've now sorted it and the panels are fitted as well as a seat cowl, the bike looks great. cheers for the help
Old 23-12-04, 06:01 PM   #5
K
Out of curiousity, what model bike have you got?
I only ask because I've recently fitted a Suzuki seat cowl to mine (a '99 X series) and it seems to sit a little high in my opinion. I can slide my little finger into the gap between it and the main tail of the bike almost all the way round.
Wondered whether this was just me?!
Old 23-12-04, 07:35 PM   #6
No, I got that as well, I shaved quite a bit off the rubber bits and that tidied it up.
Old 23-12-04, 11:16 PM   #7
K
Cool, thanks for that.
Now, where did I put that scalpel...?!
Old 24-12-04, 06:44 PM   #8
bikerskez
mines the better shape in silver and the fit is not bad, have a good Christmas all
Old 24-12-04, 10:51 PM   #9
K
So, sexy curves then.
Fitting 99-02 oem lower fairings Makalux SV Talk, Tuning & Tweaking 14 05-03-16 08:23 PM
Fitting lower fairings problems. V frustrated. etuna SV Talk, Tuning & Tweaking 2 25-08-08 09:31 PM
K4 Lower Fairings Fitting Kit booner Stuff Wanted 0 27-07-07 03:31 PM
fitting mesh to front opening on curvey lower fairings adam_castell SV Talk, Tuning & Tweaking 3 27-02-07 04:22 PM
Help needed desperate !!! on fitting lower fairings carlos19679 SV Talk, Tuning & Tweaking 15 21-01-05 03:00 PM
