I just replaced my clutch lever and gear lever... now when the engine is running i cant select any gear
![]() Can anyone help? (gotta get into work tomorrow night :/ ) also i think its the clutch line that goes in just over where the push rod goes? theres 2 nuts there that just spin freely :/ Many thanks in advance Yours beggingly ![]() Iain |
have you checked out the diags in the manuals published on this site? Sounds like you need to double check everything. The push rod has a very specific adjustment screwed in till resistance is felt, then backed off a 1/4 turn (or is it 1/2). Sorry that's not so specific! check out the manuals.
Al
SFV650 in black with Evotech tailtidy, R&G Aeros and Heated Grips, Puig fly screen, Pipe Werx GP style race exhaust. Whoop! Previously.... Black SVS - DHM's Heated Grips Airblade Iridium Double Bubble Screen Beowulf end can and Evotech tailtidy. 3/7/2004 - 26/6/2015. |
You've not adjusted the clutch cable where it goes in behind the sprocket cover then?
That'll be your problem. If you're still struggling tomorrow I might be able to help, that is if you're not going to work before 6. |
Clutch cable it be.
Buy a Haynes, easy to follow problem solving for about £15-...... At your local Halfords .... Tell 'em those cheques haven't come my way for a while now... |
been fiddling with it for about 4 hours now, still knackered.
changed the free play from slack to tight, no real change, also when i put it in 1st gear, theres a slight pull by the bike... im an engineering noob so not sure whats going on Iain |
well kept on fiddling and seems to be alot smoother now, i think its a bit 'clunkyier' now on the shifting, but ill try with 1/4 turns n stuff tomorrow, got a cracking headache now, prolly the fumes
![]() Iain |
Iain, I'm finished about lunchtime, so if this is still an issue I could call in on my way through south London (don't know where you are) if that's any help?
Will check this thread again before setting of home at about 12. Cheers Mark.
Aaargh! | yorkie_chris | Idle Banter | 13 | 24-12-07 11:37 AM |
