Old 26-01-05, 07:09 AM   #1
pegasus
pegasus's Avatar
Default clutchless downshifts ?????
bit of advice please.
do any of you nice folks shift down without the clutch? i've done it a few times purposely to see how it is..the gearbox sounds ok and the bike shifts fine but im wondering :-
1. how much damage am i causing
2. should i be doing it in the 1st place
any advice appreciated thanx.
tune in, turn on, burn out
pegasus is offline   Reply With Quote
Old 26-01-05, 07:33 AM   #2
Flamin_Squirrel
I can do it, but I don't. Blipping the throttle is faster.
As long as you're not forcing the lever, I understand it won't do any damage at all.
Old 26-01-05, 07:34 AM   #3
Junior
I imagine it would shorten the useful life of the tranny and associated parts. Is it really that time consuming to 2 finger the clutch ?
Old 26-01-05, 08:20 AM   #4
pegasus
pegasus's Avatar
not at all ...im a blipper as well..but i was just curious
thanx for the reply
Old 26-01-05, 08:46 AM   #5
ReLoAd
just a quicky in regardes to downshifting why can you go down as many gears as you like in one go but you cant skip gears going up. ie from 2nd to 4th with out it sounding like the gears are going to explode ive only done it once and it really didnt seem to like it so ive never done it again.
Old 26-01-05, 08:55 AM   #6
pegasus
pegasus's Avatar
im guessing ...its something to do with the sequential run off the gears.
i.e it might seem as if your going from 4th to 2nd but the box is actually going 4.3.2 running through the gears sequentially. going upwards is a different matter each gear has to be selected and running before the next gear can be selected..
i think
Old 26-01-05, 09:29 AM   #7
wyrdness
I've read that clutchless downshifting really isn't recomended. I'm not sure why you'd want to do it either. Clutchless upshifting is great for accelerating hard, but if you're going down the gears you should do it properly.
I've never had a problem skipping a gear on the way up (e.g 2nd to 4th). I'll do that if it's a lowish speed limit and I want to accelerate quickly up to the limit and then cruise at 40mph (or whatever).
Old 26-01-05, 09:50 AM   #8
Ceri JC
Agreed- I understand (and occassionally do) clutchless upshift. I can't see the point of clutchless downshifting. Surely even if you blipped the throttle, you'd have to be very precise with the amount of throttle, to avoid sudden engine braking.
Old 26-01-05, 10:20 AM   #9
jonboy
I can certainly downshift without the clutch and still blip the throttle, you've just got to be ultra-precise. Is there any point to it? Not really 'though it's handy when I'm on the mobile...
Old 26-01-05, 12:23 PM   #10
pegasus
pegasus's Avatar
talking or texting?
So does doing clutchless changes muck up your box? petevtwin650 SV Talk, Tuning & Tweaking 30 05-06-10 11:16 PM
Clutchless gear changes Larry SV Talk, Tuning & Tweaking 13 12-04-07 02:35 AM
Clutchless upshifting Stu Bikes - Talk & Issues 23 23-08-06 01:27 PM
Clutchless changes ThEGr33k SV Talk, Tuning & Tweaking 1 21-08-06 10:37 PM
Clutchless Gear Changes? sweepdoggydog Bikes - Talk & Issues 21 16-08-05 03:14 PM
