Old 31-01-05, 11:44 PM   #1
Lazzer
Default Annoying stickers
Hello All,
How did you go about getting rid of the annoying stickers that suzuki so helpfully stick to your bike Was gonna go at them with petrol but had visions of melting fairing and dripping paint, probably very paranoid . Suggestions welcome!
Laz
Old 31-01-05, 11:51 PM   #2
carelesschucca
carelesschucca's Avatar
If I remember rightly I peeled it off the used a touch of Petrol to take off the sticky residue. but it was 3 years ago!!!
I've had my bike 3 years at least its all mine now and I don't owe the bank anything
Old 01-02-05, 12:55 AM   #3
nuntius
You need to heat the area with a hair dryer, then peel off the transparent sticker ontop of the sticker (you don't even realise it's there).
Continue to heat, and using a plastic card (not anything you want as the haet from the hair dryer tends to melt it) push the sides of the sticker up to peel it off.
Once all the plastic is removed (it takes ****ing ages) use wd40 to remove the residue before finally using a bit of car wax to finish it off.
If you have an 'S' then the sticker on the inside of the fairing, infront of the brake lever is a lot easier to get off.
I wouldn't try petrol, and definately not in conjunction with the hair dryer
Old 01-02-05, 03:22 AM   #4
Grifter
Hey, I got the warning sticker off the tank, and no it is NOT under clearcoat. The sticker itself has a clear primary layer, that's all. Hairdryer, razor blade and 91% rubbing alcohol.
Old 01-02-05, 03:24 AM   #5
Grifter
****e, I just repeated everything!!!
Old 01-02-05, 08:11 AM   #6
Scoobs
I just lifted a corner then grabbed them with a set of pliers and gently pulled back. Cleared the residue with a bit of WD40, quick wash of the area and polish. Bob's yer Auntie's live in lover.
Old 01-02-05, 08:37 AM   #7
Cronos
4 Step Guide to Removing Safety Stickers.
1. Boil kettle.
2. Pour a small amount of hot water on sticker.
3. Gentley lift off sticker, it should come away without a problem.
4. Make a nice cup of coffee.
Old 01-02-05, 10:09 AM   #8
Captain Nemo
i intend to take the stickers off mine, but i was wondering, is there any legal requirement for any of these stickers to be on the bike, or more likely is it just Suzuki covering theie backsides in case people try to sue for not being warned that...
motorcylces are dangerous.........altough i think if you didnt realise that then you must be dead already.
Old 01-02-05, 10:14 AM   #9
Flamin_Squirrel
There is a legal requirement for the stickers to be there when the bike is first sold, thats it. Pretty stupid.
Old 01-02-05, 10:26 AM   #10
PoRk ChOp
It's all down to the American market Suzuki covering their backs
TBH How annoying is that? Stu Idle Banter 10 18-11-08 09:42 AM
So annoying timwilky Idle Banter 6 24-02-07 04:03 PM
Annoying my neighbours tricky Idle Banter 11 24-06-06 10:17 AM
how annoying medwaysv Bikes - Talk & Issues 5 23-04-06 04:07 PM
