Old 10-02-05, 02:48 AM   #1
pridhac
Default Gear selection becoming difficult
I have a 2000 model SV650S with 60,000km on it.
Just recently the gear shift has developed some problems, for example the other day I was slowing down to turn into a car park with quite a big bump for a drive-way and I was therefore attempting to down-shift to first. No good, neutral it is.
Today on my way out of a round-about I had just shifted from 2nd to 3rd which felt as though it engaged OK, but no, 100m later it pops out of third into a false neutral.
What is causing this problem? Will a detent arm kit resolve this issue? Is the gearbox becoming 'worn'??
What is the most efficient likely fix folks??
Old 10-02-05, 07:42 AM   #2
fizzwheel
fizzwheel's Avatar
Try some simple things
Have you checked your chain adjustment, also other people have posted that if you overfill the oil it effects the gear change
I've had trouble with mine and when I checked the chain it was very slack, I adjusted it and it's been fine ever since
Old 10-02-05, 11:27 AM   #3
Carsick
As fizz says, oil, chain, sprockets all need checking for overfilling/slack/wear.
Also, I've heard that clutch adjustment can affect it quite easily and the gear lever can need adjusting as well.
Old 10-02-05, 12:27 PM   #4
embee
embee's Avatar
Clutch adjustment at the gearbox end first, then the cable adjustment.
Check behind the gearbox sprocket cover for gunge (chain lube etc), clean it out as necessary.
Check gear linkage, pedal pivot etc for free movement. The pedal pivot has been known to stiffen up due to corrosion. Free off with WD40 or similar.
Other things as has been said, chain adjustment, oil level etc.
Old 10-02-05, 09:35 PM   #5
Stig
and further to the pedal pivot remark. Also make sure it's not too loose. Mine was too loose a little while ago and I found that I couldn't select gears at all.
Old 13-02-05, 05:00 PM   #6
Tony_BLY
Tis true ...
I had problem getting into first on occasion, checked chain ... fine, checked clutch ... fine, checked oil ... overfilled, drained some out, problem solved (though I ended up with hot oil over my arm (Doh!)). Could tell straight away, gear changes feel much better all round. Thanks for info guys, as a question I won't have done any damage will I? Changed oil about 2500 miles ago so I have run it for this length with a an overfill, but it has always run soooo sweet ... I know this from Friday's journey home when an Audi something-or-other fancied his chances ... opened her up ... no contest ...
Thanks again
Tony
Old 14-02-05, 08:39 PM   #7
RandyO
Clean your shift linkage
Old 14-02-05, 09:27 PM   #8
embee
embee's Avatar
Originally Posted by Tony_BLY
... checked oil ... overfilled, drained some out, problem solved .....as a question I won't have done any damage will I?
if it was only a little overfilled, and it had been running fine without lots of blue smoke, and it isn't covered in oil on the outside, and it's running fine now...........no.
Old 16-02-05, 09:04 PM   #9
Big Bad Al
Big Bad Al's Avatar
had the same thing a few weeks back. All these things already said are true but also check the linkage clamp on the splined pivot. Mine was loose and the clamp had moved off the spline by a 1/4". I pushed it back on and tightened it and it's all ok now.
SFV650 in black with Evotech tailtidy, R&G Aeros and Heated Grips, Puig fly screen, Pipe Werx GP style race exhaust. Whoop!
Previously.... Black SVS - DHM's Heated Grips Airblade Iridium Double Bubble Screen Beowulf end can and Evotech tailtidy. 3/7/2004 - 26/6/2015.
Big Bad Al is offline   Reply With Quote
Difficult to get 3rd gear Bunks SV Talk, Tuning & Tweaking 11 21-11-08 11:47 AM
Gear selection problems Stingo SV Talk, Tuning & Tweaking 8 04-09-08 05:10 PM
Gear Selection Problems Iansv SV Talk, Tuning & Tweaking 14 12-01-06 03:14 PM
Gear Selection jpb SV Talk, Tuning & Tweaking 3 14-11-05 04:17 PM
Gear Selection! PoRk ChOp SV Talk, Tuning & Tweaking 11 06-01-05 04:15 PM
