Old 24-02-05, 04:44 PM   #1
The Mass
Default Front Brake - Do you use it?
Hi all,
Mate in work reckons he uses his front brake rather than his back brake when riding.
Now I know from my SV that even if I touch the front brake, just pulling up the path to park the girl, my head near come off!
Mate's got a GSXR1000
Just to clear up this debate, what do you lot do?
Back with a bith of front?
Back only?
Front only?
Not Ar$ed - just wait until I fall off?
Cheers - Mass
Old 24-02-05, 04:47 PM   #2
Iansv
mostly use front, just use back brake for low speed braking if engine breaking ins't sufficient.....
how can you not use your front brake ? how did you pass your test ?
Old 24-02-05, 04:49 PM   #3
The Mass
Sorry Ian, maybe that cam eacross wrong, do use the front, but not as much as the back...
Maybe just because I'm learning still I guess, but was told when learning to keep off the front brake???? but I do use it..
cheers
Old 24-02-05, 04:50 PM   #4
PoRk ChOp
I use the front most of the time, infact I hardly use the back unless filtering and I keep it covered at all times when doing that
Old 24-02-05, 04:53 PM   #5
Iansv
cheers
I think your instructor probably meant keep off the front at low speed and corners not completely
Old 24-02-05, 04:53 PM   #6
wyrdness
I've heard of quite a few people who only use the front brake, and claim to never use the back. I use mostly front, with a small amount of bac, unless I'm manouvering (e.g. need to brake when filtering), when I'll use more rear.
I was taught that normally you should use about 75% front to 25% rear, or 50-50 in the wet. I used to practice hard braking by leaving it as late as possible to brake at red traffic lights. Only try this when conditions are good and you have warm tyres. You can stop much quicker with the front brake, so get used to using it. If you stamp hard on the rear, you'll lock the tyre easily.
Old 24-02-05, 05:01 PM   #7
wyrdness
Originally Posted by leesimons
If I used 50/50, I would definitely lock the rear
That's what I was taught when doing the CBT. It's a bit different once you're experienced. I do use less front and more rear in the wet though.
You need more rear brake on cruisers than on sports bikes. I was used to using a lot of rear brake on the Harley, especially when filtering. When I got the Ducati, I started off riding the same way and would end up boiling the rear brake fluid. I had to improve my riding style so that I didn't brake so much when filtering.
Old 24-02-05, 05:01 PM   #8
The Mass
Well well....I've actually learnt something today!
Cheers you lot !
Maybe it's just me, a bit heavy handed on the brake lever with my right hand, will be learning that one then - VERY SOON!!
Nice 1
Keep up the good work you SV'rs and Others
Old 24-02-05, 05:06 PM   #9
BURNER
I use front brake except when moving slowly or manouvering on dirt.
If you change the soft stock springs you won't have as much nose diving and the brakes will feel much more progressive than the on/off you've got now.
Old 24-02-05, 05:15 PM   #10
jonboy
Err, you should do the majority of your braking with your front brake (unless you're a freak like Greg!
Yes I agree to being somewhat controversial here in that I use 80% back brake to 20% front (if that). I'm used to it, it suits me - certainly it doesn't slow me down .
Find what suits your own style of riding but do try both and don't dismiss the rear brake like a lot of people do, as the rear is a very useful tool if used correctly (or even abused by me). So many people lose the front under braking (often through over-use whilst panicking when an emergency situation arises) where had they used the rear first to start the slowing of the bike and make it more stable they might have saved the day.
Contrary to popular belief (it seems) the SV has quite a good back brake. It's there for a reason - try it, you might like it .
WTD - rear brake lever, front brake lever, r & G crash bung, nik_nunez Stuff Wanted 0 17-10-08 08:27 PM
Front Brake - Rear Brake? Stradders Bikes - Talk & Issues 35 17-09-08 04:44 PM
K3 front brake lever, Front indicator (RH), Front Mirror(RH), Bar End (RH) leegriffiths128 Stuff Wanted 0 23-07-08 09:11 PM
Front brake not activating brake light properly SVeeedy Gonzales SV Talk, Tuning & Tweaking 5 27-02-07 12:09 PM
brake light flickers when the front brake pulled in - K4 dclifford SV Talk, Tuning & Tweaking 9 05-09-05 10:39 AM
