Old 07-03-05, 11:30 AM   #1
shutdown
Default Service cost
How much would you pay for a service?
I need the brakes looking at mainly as they don't seem to "right" esp the rear!
Just knowing how much to put back ready for a service in a couple of weeks.
I'd love to do it myself but have no clue about that stuff
Old 07-03-05, 11:41 AM   #2
Scoobs
There is no fixed cost for brakes as it all depends on how long it takes to do. Can be a quick seal service. 1hr ish. Or it could be a flipping bugger in which case you are better of getting a couple of decent calipers from a scrappy. I got two fronts for £60. Seal kits and labour aren't going to be much less than this. Could even be quite a lot more if they are well seized.
Old 07-03-05, 11:43 AM   #3
Cloggsy
You can look at anywhere between £35 & £55 an hour + parts
Make sure you get a written quote first
Old 07-03-05, 11:55 AM   #4
Warren
brakes are pretty easy.
take the calipar off, spay loads of brake cleaner in the calipar and clean it with a soft brush.
check your pads.
disc thickness
clean the disc
also , press the piston as far in the calipar body as it will go (as this apparently gets all the tiny air bubbles out of the fluid - someone did this to my calipar - and afterwards - it felt brand new)
take some brake cleaner, spray loads on the pads, and scrub a little with a green scourer (to remove glazing)
also check your brake lines for any leaks, and check you fluid level.
Old 07-03-05, 11:57 AM   #5
Cloggsy
Originally Posted by bikageboy
spray loads of brake cleaner in the calipar and clean it with a soft brush.
... ensuring you've removed the brake pads first of course
Old 07-03-05, 12:18 PM   #6
Scoobs
Why!
Brake cleaner will not affect the pads.
Old 07-03-05, 12:19 PM   #7
Cloggsy
Wouldn't you rather remove them first Damn sure I would
Cost of 15k service Mr_Chin Bikes - Talk & Issues 11 01-12-08 09:51 PM
Service intervals and est cost nik_nunez Bikes - Talk & Issues 1 28-06-08 07:01 PM
Cost of a service? kd sweety SV Talk, Tuning & Tweaking 2 01-03-08 04:22 PM
How Much!!! Service cost red5 SV Talk, Tuning & Tweaking 3 21-03-05 03:00 PM
How much should a 4K service cost?? valleyboy SV Talk, Tuning & Tweaking 24 12-12-04 09:55 AM
