Old 09-03-05, 06:20 PM   #1
leatherpatches
Default Clutch suddenly stiff
Got on the bike this morning and the clutch lever felt suddenly stiff. My questions are:
1) Is this likely to be the beginning of the end for the clutch (like it is if a car clutch gets stiff)?
2) I have done about 13k miles since new. Is this normal mileage for a clutch or should I be expecting more?
3) If this is a short life for a clutch on an SV, am I likely to get a new one under warranty? I'm not really a hard rider and very rarely blast away from the lights.
Many thanks.
Old 09-03-05, 06:20 PM   #2
leatherpatches
Oh, I should have said, it doesn't 'feel' like a lube problem near the lever itself, but I may be wrong.
Old 09-03-05, 06:28 PM   #3
dirtydog
Knob faced knobster
dirtydog's Avatar
it might be the cable needs lubing
although that probably wouldnt happen suddenly
Old 09-03-05, 07:46 PM   #4
leatherpatches
I'll check the cable, but I suspect something more? Anyone any ideas?
Old 09-03-05, 08:27 PM   #5
embee
embee's Avatar
I'd have a stab and say it's unlikely to be a problem with the clutch unit itself.
My guess would be either the cable (for example a broken strand inside somewhere which could be causing some binding), or possibly something gone awry with the release mechanism which is mounted behind the gearbox sprocket cover.
Take the sprocket cover off, it's 4 bolts. You need some sort of small body socket to get into the counterbores. Note the cover is plastic so you need only gentle hand pressure when re-tightening.
See whether it's gunged up in there or rusty even.
Check the manuals for how to adjust that mechanism.
http://www.sv650.org/sv_manuals.htm
The release mechanism has ball bearings running on ramps, so it's just feasible for something to have got out of place.
Old 09-03-05, 10:30 PM   #6
Stig
How about the lifter???? Mine is on its way out too. The cable could have a kink in it.
Stiff clutch - painful hand ArtyLady SV Talk, Tuning & Tweaking 19 23-05-08 10:30 PM
So, is it too late to suddenly decide to go to the NW200? northwind Idle Banter 8 11-05-08 06:45 PM
Tyres wearing out suddenly Ceri JC SV Talk, Tuning & Tweaking 21 29-08-07 09:31 PM
Clutch lever is very stiff The Mass SV Talk, Tuning & Tweaking 2 08-06-06 12:48 PM
Clutch and throttle stiff to use - cable oilers??? huge SV Talk, Tuning & Tweaking 13 23-05-05 09:51 PM
