Ancillaries Post your own reviews, opinions and experiences on various other bits and bobs, such as rearsets, oil, engine bits.
Old 10-03-05, 04:39 PM   #1
chewy22
Default Bolt kit review 03>05
Ok having looked at my post http://forums.sv650.org/viewtopic.ph...205&highlight= I see about 930 plus have had a look and approximately 20 have perches the bolt kit for the 03>05 SV650
But I suspect most are still awaiting the long awaited review on the kits.
I think it’s very important I get feed back to make sure I have got it right and also put anything right if I have over looked something.
So what I need to know is the instructions OK are all bolts covered that you expected to be.And a tru opinion on the kit and service.
Thanks for any replies.
chewy
www.chewys-stuff.co.uk/
Old 10-03-05, 04:42 PM   #2
Cloggsy
Chewy,
Sorry for the delay, I haven't even looked at fitting my kit yet
As soon as I do I will post feedback about the kit...
Hopefully someone else will fit their kit soon & feedback will be forthcoming
Old 13-03-05, 05:53 PM   #3
chewy22
Only one ?
Sent via PM
Only a little niggle about the bolt kit, there arn't any tank bolts or the bolts for the little plastic side covered. I've used overs from the kit but, might be worth thinking about including.
I did look at these but they did seem good quality. So I didn't feel the need to replace them.
Old 15-03-05, 09:26 PM   #4
chewy22
BUMP
Old 16-03-05, 11:07 AM   #5
PoRk ChOp
I will be fitting mine this weekend.
I will give you a full report on how I get on, and the good/bad points of the kit.
Old 20-03-05, 04:15 PM   #6
PoRk ChOp
Right, I have finally put my bolt kit on the bike (well most of it)
The quality of the bolts are fantastic
The instructions are spot on for someone with no mechanical skills whatsoever. I managed to put all the engine bolts on (apart from one) without any problems at all.
Chewy - can you recommend a way of getting the bolt out from right under the engine above/behind the exhaust? I have given up for the time being
My only critisism of the kit is the final bag of bolts, I didnt have a bloody clue where or what to do with them (it may be in the instructions and I may have missed it, If I have then let me know)
Well done to Chewy for helping to get rid of all that Suzuki cheese
Old 20-03-05, 05:12 PM   #7
chewy22
quote My only critisism of the kit is the final bag of bolts, I didnt have a bloody clue where or what to do with them (it may be in the instructions and I may have missed it, If I have then let me know)
There should have been a long list with the kit. If you sort them out by type and size start at the top and work your way down should be simple to do.
Old 20-03-05, 05:55 PM   #8
PoRk ChOp
Your right, sorry mate
In that case the kit is spot on
Old 27-08-05, 10:19 AM   #9
chewy22
No problem.
Fairing bolt / Mirror bolt MiniMac Stuff Wanted 0 02-07-08 10:26 AM
how to get the sump plug/bolt or filter bolt out without murdering someone? Paul the 6th Bikes - Talk & Issues 11 31-05-08 10:49 AM
The TWO Review would like your help TWO_Review Bikes - Talk & Issues 79 05-02-08 12:31 PM
Help me build a spare bolt box; what are all the common bolt F16Falcon SV Talk, Tuning & Tweaking 10 07-05-07 08:42 AM
Seat Bolt and bar end bolt Colby Stuff Wanted 3 04-04-07 04:56 PM
