Old 11-03-05, 02:00 PM   #1
Bikeman
Default Brakes binding?
Getting back on the bike after a couple of weeks lay off, I noticed that the it was very difficult to move whilst in neutral, as if the brake were being applied. After riding for a bit they seem to free up, but the same problem seems to happen after leaving it for a day, although not as bad.
Could this be the brakes, or could it be the wheel bearings?
Any suggestions welcome.
Old 11-03-05, 02:17 PM   #2
Most unlikely to be the wheel bearings, the finger of suspicion points at the brakes, but you knew that.
Old 11-03-05, 03:05 PM   #3
Bikeman
Thanks, I thought so, I will give the brakes a good once over at the weekend.
Old 11-03-05, 04:42 PM   #4
Red ones
Red ones's Avatar
Easy way to tell if it is the brakes.
Ride for about half a mile, then get off and see if any disk is hot or turning blue.
I suspect you have the fronts binding - they suffer easily will road salt on the caliper seals
Old 11-03-05, 05:39 PM   #5
Warren
had the same problem
turns out one of the pins was seized, and it needed freeing.
was a bugger to free up, but its sorted now
Front brake binding after drop - help? branny SV Talk, Tuning & Tweaking 8 29-12-08 09:04 PM
Pointy Rear Brake Binding Cleaning glade SV Talk, Tuning & Tweaking 0 12-07-07 09:54 AM
Rear Brake binding 2mths SV Talk, Tuning & Tweaking 5 06-04-07 09:30 PM
Binding Calipers... Daimo SV Talk, Tuning & Tweaking 9 20-11-06 05:07 PM
Help! Binding of some kind... Spookinghound SV Talk, Tuning & Tweaking 8 24-11-04 09:39 AM
