Old 14-03-05, 07:26 AM   #1
MitchC
MitchC's Avatar
Default Brighter Headlight Installation...
Hey,
I have been reading on other forums about brighter headlights. It will improve my view and how people see me, which is a plus. A common suggestion is the Philips H4 Vision Plus bulb. They are $40.00 CAD (~£17.00 GBP). They are 55/60W bulbs, which is the same as my SV, correct? I am worried about the installation, anyone ever upgrade their headlights before? How difficult is it? I am not sure what needs to take place to get the headlamp down to this stage... Thanks for all your help.
Mitch
2003 Suzuki SV650S Silver
Keep your feet on the pegs and keep your right hand cranked.
Did your right hand write a cheque that your rear tire couldn't cash?
www.MITCHCAVE.com | I Do It With Twins
MitchC is offline   Reply With Quote
Old 14-03-05, 08:13 AM   #2
Red ones
Red ones's Avatar
I think the original bulbs are 45/50w though I stand to be corrected. HAving said that I changed the lamps on my SY in about the first few weeks. There are rumours that you can brown the plastic lens on the SV if you uprate the lamps, though after 4 years I have not noticed any change.
To be honest, it is probably only worth doing is you do a LOT of nightime riding, otherwise you won't notice much difference
Old 14-03-05, 08:16 AM   #3
jonboy
An excellent upgrade. Those Philips bulbs do make a difference - not an order of magnitude just better sharper lighting.
Old 14-03-05, 08:32 AM   #4
MitchC
MitchC's Avatar
Originally Posted by Red ones
I think the original bulbs are 45/50w though I stand to be corrected...
See here.
I am still most concerned on the installation... Sounds like a good mod for not alot of money. Do you think it makes you more noticeable? I was just assuming...
Mitch
Old 14-03-05, 08:41 AM   #5
Viney
See here.
Mitch
I have been through several different bulbs, and the best of the best is the Osram Silverstars (55/60w) Theya re worth while imo, and are easy to fit. Remove plug on back of light, remove rubber boot thing, unclip the bulb, put new bulb in and reverse the removal procedure. its only the cheaper bulbs that will 'brown' the lens as they dont have good enough UV filters. Top brands like philips and Osram etc are fine. If you have money to burn, then search out some PIAA super whites. Expensive, but run rings around anyother brand on the market.
Old 14-03-05, 08:53 AM   #6
fizzwheel
fizzwheel's Avatar
I've got PIAA Superwhites in my car awesome bulbs
Old 14-03-05, 08:58 AM   #7
jonboy
You're a rich man .
Old 14-03-05, 09:27 AM   #8
Viney
Originally Posted by jonboy
You're a rich man .
Maybe, but at lest he can see where hes going
Fizz, have you thought about tyring them in your bike, assuming that the car uses H4 bulbs that is?
Old 14-03-05, 09:38 AM   #9
Grinch
I should hope so.. 75 quid... viney where did you get those others from? and what sort of price was it?
Old 14-03-05, 09:51 AM   #10
Viney
Er, the silverstars do you mean? £20 if i remember rightly from http://www.startledrabbit.com/
head light getting brighter larigos SV Talk, Tuning & Tweaking 1 18-01-09 02:10 PM
Why do my lights get brighter when I rev the engine? thor SV Talk, Tuning & Tweaking 53 17-01-09 10:12 AM
Brighter Bulbs What are the ones? k146 SV Talk, Tuning & Tweaking 56 11-12-07 01:58 PM
Brighter Bulbs k146 SV Talk, Tuning & Tweaking 31 22-08-07 04:59 PM
Brighter Lights echomadman SV Talk, Tuning & Tweaking 14 13-04-05 06:41 AM
