Old 17-03-05, 06:41 PM   #1
Silver Dream
Default Question re style v indictors
Just picked up a pair of clear flush indys (impulse buy), plan was to use on the rear, however having looked at the bike the aftermarket tray would suit small arrows better. Therefore could I use them on the front?
Looked at the positioning that would be required to cover the hole left by the standards indys
Te question is ... Has anyone done this ?
Are the indys visiable from the front to oncoming cars... Dont want to get wiped out!!!
How do I know if I will need flasher unit/restictors if I run Flush on the fron and some mini arrows to the rear?
Help - lecy is not my thing!!
Ta
Old 17-03-05, 06:48 PM   #2
hall13uk
you can fit them to the front but there barely visable in daylight. and not much better at night i changed mine and got led arrows from motrax there great make sure you get the short stem ones thou. when you drop it you will be glad you did. (wont crack fairing )
Old 17-03-05, 06:54 PM   #3
hall13uk
oh you will need a resitior if you get the led arrows there about £9.00 i recomend you get things like this fitted by someone who is well qualifed (your dealer/trusted friend) best not to take any chances with this kind of stuff
Old 17-03-05, 09:00 PM   #4
stumpy1
howdy hall13uk just read your post on led's from motrax are they the new ones with the resister in the packet ,or the old style with out ?
i have fit a full set with the resisters and they still flash fast ,were did you get yours from and how did you fit them
cheers stumpy1
Old 17-03-05, 09:09 PM   #5
Cloggsy
Get in touch with Motrax, they sent me a new set of 'proper' resistors for free
Old 17-03-05, 09:42 PM   #6
stumpy1
cheers cloggsy but my local bike shop already tryed that and they were going to charge 5.80 each for the pleasure of a resister, that was more than the flasher unit you could get fot 19.99. what are they playing at why don't they just send them if you need them. you must have been one of the lucky ones cloggsy .
thanks anyway
stumpy1
Old 17-03-05, 10:21 PM   #7
Cloggsy
My e-mail to the went along the lines of:-
"I bought an item which isn't fit for it purpose, you are now telling me that I have to buy an additional piece of equipment to make the item which I originally bought work... Doesn't sound right to me, perhaps I had ought to take some Trading Standards advice on the matter..."
Funny old thing, the resistors arrived the very next day - 1st class recorded...
Old 17-03-05, 10:33 PM   #8
mattSV
mattSV's Avatar
£5.88 for resistors??????
They are taking the p*ss.
Mine were 19p each from Maplins - see here:-
http://www.maplin.co.uk/Module.aspx?...dID=3&doy=17m3
2000 - 2004 SV650S
2004 - 2009 SV1000S
Old 17-03-05, 11:20 PM   #9
stumpy1
cheers guys, mattsv when you fit your resisters did you just soldier them onto the original or did you make your own cables ?
cheers stumpy1
Old 18-03-05, 09:12 AM   #10
mattSV
mattSV's Avatar
My motrax LEDs came with resistors already fitted, however they still flashed too fast.
I chopped off the original resistors and soldered in a 10 watt 10 ohm resistor in their place in parallel (i.e. ACROSS THE WIRES) - didn't need to make any other cables up, other than having to chop off the connector block from the OE indicators and connecting that to the new LED indicators.
I was looking at an SV last week that had flush mounts fitted to the space where the OE indicators were, however he also had converted the sidelights to indicators so visibility from the front was not an issue.
UPDATED - just realised yours is a curvy so doing the sidelights is not an option for you
2000 - 2004 SV650S
2004 - 2009 SV1000S
SV OCC style! Jester666 Photos 19 16-07-08 05:06 PM
Newbie style question Wideboy Bikes - Talk & Issues 39 12-07-07 04:41 PM
old style R&G's kwak zzr SV Talk, Tuning & Tweaking 2 25-11-06 11:39 PM
2/3 of a set of new-style R&Gs for curvy northwind For Sale - SV's and SV related items 1 28-02-06 09:31 AM
Tail in the air look...MV style Vtwinlover Bodywork 16 30-01-06 08:40 AM
