Old 19-03-05, 10:44 PM   #1
snoopy
Default Inverted Rear Caliper: Curvy to Sharpy style
Today I was messing about today getting my calipers ready for power coating and had to remove my rusting torque arm.
Then it hit me there's no reason the curvy SV can not be like all the new bikes and have the caliper on-top rather than below.
All you need to do is loosen the rear wheel, bash the caliper holder round with a rubber mallet and re-fit. Move the hose next to pump 90 degrees clockwise to remove new slack and it fits fine.
Then need to make a torque bracket that fits to the swingarm, a little more difficult but not impossible.
Just a thought. Has anyone else tried it?
Old 20-03-05, 02:04 AM   #2
I've seen it done on race bikes, but only when the rules required a rear caliper but the rider didn't expect to use it... To make it actually work would be trickier... You thinking of puting a bracket around the swingarm, sort of thing?
Old 20-03-05, 07:05 AM   #3
timwilky
timwilky's Avatar
Andrew
Please think about it.
Firstly I doubt that you could move the caliper 90 degrees as it would strike the back section of the swinging arm you would be looking more at 150
Secondly the air in the caliper need to be bled. to do this you must have the bleed nipple at the highest point otherwise you would get an air lock.
moving the caliper through 90 degrees would ensure about 40% air in the caliper and to move it further simply increases the amount of air trapped in the caliper.
OK other threads have asked about who uses thier rear brakes. You might not, even for emergencies. But I do think the C&U Regs to require the brake to work.
Not Grumpy, opinionated.
Old 20-03-05, 08:07 AM   #4
It might be easier to another suitable caliper, if you spin the support bracket 180 degrees it will be fine, but the torque arm lug on the caliper will be at the back.
Whole job is way more trouble than it's worth.
Old 20-03-05, 09:14 AM   #5
snoopy
The caliper goes 180 degrees + but the pipe at the cylinder ends needs to be moved 90 degrees to take up the slack.
Northwind, my idea exactly. Means no torque arm to worry about and the caliper wont get crap in it.
Brake still works fine. It's an idea anyway.
Old 20-03-05, 11:51 AM   #6
Dan_SV
Do it Andrew, it sounds like another of your groundbreaking great ideas...
snigger
Dan
Old 20-03-05, 07:27 PM   #7
TSM
The Sick Man
TSM's Avatar
just an idea does a K3-4 swingarm fit on K1-2?
Old 20-03-05, 09:26 PM   #8
Tim has a good point about bleeding the caliper... You'd need to do it right way up then turn it over, and it might still have a tendancy to gather air in the pistons- though of course a well bled system won't have any air in it anyway.
It seems to be a fairly common mod with the wee Brembos for US race bikes, but they're either not very functional, or butt ugly, and no room inbetween. Sid's right that you'll be left with the torque arm mounting on the wrong side, which is going to look rotten... But it should be relatively simple to brace it, since the rotational force would spin the caliper towards the swingarm- it's easier to brace for pushing towards than it is for pulling away.
It's an interesting idea, but the skeptics win Unless you were doing it with a totally new caliper and bracket, it's never going to look better than a bodge IMO.
Old 20-03-05, 09:36 PM   #9
DeeJay
forget it mate... never try and mod your brakes.. it is simply not worth it...
Old 20-03-05, 09:38 PM   #10
jonboy
Could also invalidate your insurance in the event of a claim.
curvy rear caliper and torsion arm trouty Stuff Wanted 0 09-05-09 01:21 PM
Wanted - rear caliper for a curvy bad_hat_harry Stuff Wanted 0 20-11-06 08:13 AM
Curvy Rear Caliper Mount Ter Stuff Wanted 1 06-09-06 10:15 AM
old style curvy rear LED light falc Bodywork 2 04-05-05 11:02 PM
K3+ rear caliper on a <K3 curvy snoopy SV Talk, Tuning & Tweaking 9 30-03-05 06:49 PM
