Old 20-03-05, 07:30 PM   #1
fizzwheel
fizzwheel's Avatar
Default Tyre Pressures
I'm running BT-020's front and rear
I'm running standard pressures as dictated on the chain guard, 33 front 36 rear, I know these are for the Metz 4 tyre
What pressures does anybody else use in the BT-020 tyres and will it make that much difference ?
I feel very very comfortable with things like they are which I think is the most important thing I think
Old 20-03-05, 07:33 PM   #2
Red ones
Red ones's Avatar
35/38 for me - loverly
Old 20-03-05, 07:36 PM   #3
Sudoxe
Standard for BT020's are 31?/36. which is what im running on at the moment.
When i first got them, I had them running at 31/41, Which was erm, intresting (Use to have A D307 rear, thought it was the same pressures ) It tipped in a fair bit faster, felt like it was about to slip on corners etc...
Dan
Old 20-03-05, 07:43 PM   #4
Red ones
Red ones's Avatar
Somewhere there is a website (Avon, I think) that runs through the theory. Tyre manufacturers are supposed to heading toward a standard pressure, at the moment they are not the same for all makes of tyre. Avon suggest 38/42
Old 20-03-05, 08:13 PM   #5
Stig
To be honest tyre pressure is a personal thing. People on this site ride with all different pressure levels in their tyres. I would suggest you set them as stated on the chain guard and then dabble with the pressures and find a happy medium that suits you.
Old 20-03-05, 09:19 PM   #6
Iansv
usually run 33/36, currently trying 35/40
Old 24-03-05, 07:59 AM   #7
Red ones
Red ones's Avatar
Here you go...
http://www.sv650.org/sv_faq.htm#24/0...0Some%20truths
Hope you have time to read it![/url]
Old 24-03-05, 08:54 AM   #8
H-Gerickemark
what about the pressure ratings the tyres have on them?
I normally use them - should I or shouldnt I???
Old 24-03-05, 09:10 AM   #9
wheelnut
I believe the tyre pressures marked on the casing are a maximum at a set temperature to be used in the USA and are not applicable here.
As big ape says, tyre pressures are very personal. I think with the modern technology in tyres requires less pressure than older tyre types.
Truck Tyres used to be inflated to 110 psi to carry loads of 32tonne, now they are inflated to 85 psi and carry 44 tonne.
I believe Bike tyres are the same, the carcass has to move to heat up the chemicals in the rubber,
My opinion only, but I think 42 is much too hard for these modern tyres
This post will cause some argument I think :P
Old 24-03-05, 09:14 AM   #10
will
out of interest, i have just called pirelli customer services - manufacturers recommended for diablos on SVS K3 onwards is 33F/36R
has anyone tried a different set up with diablos, and what did you think?
Tyre pressures AndyBrad SV Talk, Tuning & Tweaking 33 05-09-08 09:10 PM
Road Tyre Pressures and tyre problems G Bikes - Talk & Issues 14 05-06-08 03:29 PM
Tyre Pressures redbiker 954 Mini-Twins 5 21-02-08 10:25 PM
Tyre pressures mxm35948 SV Talk, Tuning & Tweaking 13 10-09-07 04:18 PM
Tyre pressures - help! benny SV Talk, Tuning & Tweaking 3 03-04-05 08:43 PM
