Old 27-03-05, 10:31 AM   #1
zesty
Default Gear change selector
Hi.
Any ideas where I can get a replacement gear selector from for my K2 cos I snapped mine? Either second hand or new but cheaper than the dealer.
Old 28-03-05, 10:43 AM   #2
Mariner
Demon Tweeks had gear lever and brake pedals for £59.88 and £51.74 respectively, but I think that is about the same as Suzuki charge. They are made by Woodcraft and can be found on page 186 of the 2005 catalogue.
I'm sure I've seen a budget range at £40 each, possibly M&P!
Old 28-03-05, 04:04 PM   #3
Couerdelion
Could try these...
http://www.patternparts.net/
You will probably have to ring them as I cand find the item on the site.
Old 28-03-05, 08:28 PM   #4
BURNER
ebay, look for SRAD items they'll fit.
Old 28-03-05, 08:36 PM   #5
Carsick
Which bit is snapped? If it's just the part with the rubber, then it's easy enough to drill through and put a bolt in with a locking nut the other side. Works even better if you thread the hole.
gear selector rod thing husky03 Stuff Wanted 7 31-01-08 07:02 PM
Gear selector problems gemma1675 SV Talk, Tuning & Tweaking 1 05-09-07 11:49 AM
Gear Selector Jammed gman SV Talk, Tuning & Tweaking 9 10-12-05 07:13 PM
Gear Selector Foot Peg T0mm0 SV Talk, Tuning & Tweaking 17 10-08-05 02:38 PM
Gear selector for my Sk1 sexysi SELKENT 4 22-04-05 03:42 PM
