Old 27-03-05, 06:26 PM   #1
Anonymous
Default Leaning
How far can the SV be leant over* before either:
a) it lowsides
b) slides, digs-in and then highsides?
* <sup> assuming a standard, dry, clean road - ambient temperature 18 degrees C. </sup>
Old 27-03-05, 06:28 PM   #2
Depends on the tyres, the setup, the road and the rider, basically. There's no absolute answer. I will say that on good tyres and the right road you can grind your pegs before you run out of grip, no problem.
Old 27-03-05, 06:35 PM   #3
alka
Is there any warning before IT happenes?
Old 27-03-05, 07:35 PM   #4
21QUEST
21QUEST's Avatar
Yeah. You can usually either hear yourself think something along the lines of 'Oh ****e'. After that enjoy the ride
Ben
Nemo me impune lacessit.
Old 27-03-05, 09:22 PM   #5
Sudoxe
The back will slide/step out quite nicely (It must look really cool, quite scary when you first do it though)
Although saying that i've not had my pegs down on my S (Did on a N though, completly unintentionally)
Dan
Old 27-03-05, 11:40 PM   #6
RandyO
I have scraped my bar end mirror as well as my brake pedal, exauts pipe & can and my saddlebags no, I don't want to lean that far on a regular basis, I still think I crashed, but somehow the SV uprighted itself perfect at the exit of the blind decreasing radius corner I took a little hot.
what I lernt, don't panic, countersteer to hold you line, and no abrupt throttle or brake inputs at that tilt
Old 28-03-05, 08:08 AM   #7
wheelnut
The passenger screaming can give you a clue too :P
Old 28-03-05, 08:12 AM   #8
hall13uk
yeah bet i looked ****ing cool thou!!!!!
Old 28-03-05, 08:17 AM   #9
Carsick
Default Re: Leaning
a) it lowsides
A very long way.
You'll easily scrape pegs before it'll give you any problems.
Old 28-03-05, 06:42 PM   #10
adam
yer i scaped the pegs today , had the mrs on the back too - though i expect that would be considered cheating since the bike is a lot lower with us both on... certainly wasn't about to lowside anyway
Leaning to the right slighty svrich_01 Bikes - Talk & Issues 11 13-08-08 07:19 AM
Cornering/Leaning iane Bikes - Talk & Issues 37 10-04-08 10:05 AM
I'm leaning on a lampost- TSM Quiff Wichard Photos 9 03-07-07 05:14 PM
Cornering? Leaning? HELP HalesowenNick87 SV Talk, Tuning & Tweaking 40 21-05-07 07:31 AM
Leaning over sweepdoggydog Bikes - Talk & Issues 2 26-10-06 07:00 AM
